Question about Tissot PRS 200 Wrist Watch
Why is tissot second counter is not working properly?
Tissot lelocle is loosing too many seconds a day and second hand jumps several times between second 10 and 25. Is there anything broken?
take it back for a warranty inspection / repair or refund
maybe it is not genuine brand but a knock off in which case the manufacturer would like to be told about
Jun 15, 2017 | Tissot Watches
Does the Tissot PR516 T044.417.21.051.00 use a battery? My second hand is not moving when i start the timer and the night vision is terrible.
Yes, it does require a battery. I believe a 394 is the correct one to fit, but I'd suggest you took it to a professional rather than attempt a battery change yourself. I hope this helps.
Oct 13, 2015 | Tissot Watches
The 60-second counter hand shakes slightly when watch is tilted.
I don't think it is normal for hand to move when tilted. what about the warranty? Tissot must cover your watch under the warranty. Mind you I had a similar experience with Samsonite luggage and despite International guarantee, they did not honor. I have lost faith in some brand names.
Mar 24, 2014 | Tissot Mens T-Sport Titanium Chronograph...
Hi I have a Tissot T Race watch (model # T011417 A). It is still under gurantee, but I noticed that every 24 hours, there is a delay of 5 seconds in the watch; in other words (1 minute and 10 seconds...
I agree with the repair service, in that it probably is not a big deal, but since it is still under warranty, I would contact Tissot at the following to get their professional advice on their product.
http://www.tissot.ch/?mod_contact
Best wishes.
Aug 12, 2010 | Tissot T Race T90444631 Watch
Battery was replaced by a jeweler. Since that
As the jeweller is not a watchmaker, he/she even did not realise the watch is not working properly. It sounds like your watch is having jammed gear train or the jeweller did not know how to reset the watch. Go to this website: www.tissot.ch
If you will not find solution there, you will have to look for watchmakers help.
Rate me, please.
Jul 29, 2009 | Tissot Prc100 T22268631 Watch
Tissot PRS 516
Your Tissot watch is a chronograph. The large second hand is for the stop watch only. There is another second hand by the six that is for the time. To get the large second hand to move hit the top right button, that works the stop watch. If you already knew this and your large second hand is not going around then there is something wrong with the watch either a battery or needs service.
Mar 08, 2008 | Tissot PRS 516 T91142651 Wrist Watch
Tissot PRS 200 cannot reset counter hand (the counter stuck especially in the morning)
The owners manual mentions how to fix this but the instructions are not 100% clear. You can download the PRS200 manual here:
http://www.tissot.ch/data/usersmanual/134-en.pdf
Each of the 3 chrono hands are reset separately. Unscrew the crown and pull it all the way out (2 stops out). Press button A (top right) as many times as necessary until the hand is on the 30. Each press moves the hand one tick so you may need to press it several times.
Next push in the crown one click.
Press button B (bottom right) as many times as necessary to advance the 60 second hand to 12'oclock.
Press button A to advance the 1/10th hand to 0.
The part I did not get at first is the fact that you need to press the A and B buttons several times to advance each hand 1 tick at a time until they are all pointing to 12'oclock.
Oct 22, 2007 | Raymond Weil W1
Tissot watch prs 516 automatic
I would recommend going to the following link and follow the instructions for resetting the counters and see if that corrects the issue.
Jun 19, 2007 | Tissot PRS 516 T91142651 Wrist Watch
Tissot PRS 200 Wrist Watch Logo
43 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
