We have a Fellowes MC 460Cs shredder at our office. One day, while shredding, the blades stopped turning and it was making a strange sound. We turned it off and tried to clear any jams that were inside. It still does not work. The blades will not turn, forward or reverse, and it still makes a strange noise. If you could provide any assistance in this, it would be greatly appreciated
    President:
  • 3,085 Answers
No spare parts available....Sorry.
Posted on Jun 24, 2009
We have a Fellowes Powershred C0320C shredder which will does not take the material to be shredded except on one end and does not pull it in and shred it.
Try to use the reverse action of the shredder. This runs the shredder blades in reverse and sometime CLEARS the left over shredded material that can cause a malfunction. Careful...watch your fingers as the blades are sharp and they can injure you. Never place your hands or garments near the open blades when it is plugged in.
Check also that the small switch is free and clear of derbies. When the cutting gears are in place on the container box, the small actuator switch is free to turn on or off until the shredding box is full. Once the box is full of shredded material the switch will turn off (a safety provision) and you must empty the container before it will operated again.
Jan 12, 2018 | Fellowes Office Equipment & Supplies
CAN THE BLADES ON A FELLOWES 99Ci SHREDDER BE SHARPENED?
I do not believe so. Never heard of sharpening one. The shredding blade is pretty complicated. The manufacturer has a good support web page I suggest contacting them. Keep it clean and oiled and it should last a long time. And do not shred stuff listed on the cannot shred list.
Feb 06, 2015 | Fellowes SB-99Ci Shredder
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
Our C220c shredder does not shred, motor turns and blades turn but i think the blades are blunt. Can you get new ones or have the old blades sharpened?
There are 2 shafts that have the cutting blades on them and they both should turn. I have replaced many gears on this model and suspect that a gear is broken. Fellowes does not have many parts this model anymore. I would call a local shredder repair service or you can call Fellowes at 800-955-0959.
Sep 11, 2013 | Fellowes 220C-2 Shredder
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
Makes noise blades don't move
you have some teeth missing off of one of the gears, most likely the dual gear thats driven by the motor.
razors
Apr 23, 2010 | Fellowes 220C-2 Shredder
Shredder starts to shred, then makes a loud noise, and blades don't turn
sounds like a couple of teeth on a drive gear may be broken. call Fellows at1-800-955-0959.
Dec 01, 2009 | Fellowes DM15C Shredder
Where do i put the oil in a fellowes ps80c-2 paper shredder
You put it on the blades. Turn the shredder on to manual and oil the blades, do not oil as you are shredding. You will hear the motor start to speed up as you do this.
May 25, 2009 | Fellowes PS80C-2 Shredder
Shreds halfway, then stops. Fellowes SB-95C
on the underside of the shredder, at the top of the space where the cuttings box is, there are 2 sensors, 1 at either end of the shredder blades. it sounds like these sensors could be either dirty, or defective. try to clean these with a cotton bud or similar. it may need new sensors, bu it is worth a try!
Jan 30, 2009 | Fellowes SB95C Cross-Cut Shredder
230 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
