Question about Vehicle Parts & Accessories
How do i find out what size engine when i just have a bare block
  • 4 Answers
Posted on Sep 07, 2014
    Master:
  • 710 Answers
One way is to check the casting numbers. The other is to measure the bore, but without a crank shaft you cannot determine the stroke and therefore cannot calculate the engine size.
Posted on Sep 02, 2014
How do i fix my lights, They get dim when I hit the gas to hard or even when I hit a bump,just rebuilt the motor and didnt hook up a couple ground straps to the block. could it be a voltage regulator?
The alternator is grounded to the engine block. The lights and most of the accessories are grounded to the chassis. Since the engine and transmission are mounted on rubber shock mounts, they are isolated from the chassis. What is probably happening is that because you have no solid ground bonding strap from the engine block to the chassis, ground is being made thru some other, high-resistance path, such as , say a transmission cable linkage that connects from the column/floor shifter to the transmission. This causes a voltage drop and reduces voltage to the electrical items. This problem will eventually damage the voltage regulator and alternator as it must work harder to maintain proper output. Get a bonding strap from a bare metal point on the engine block to a bare metal point on the firewall ASAP.
Nov 13, 2015 | Cars & Trucks
Jeep block casting code 53008403
what are you doing> , buying a bare block?
why not say what is in hand. (fit what? just tranny and mounts or what? , be legal or make EFI happy, or ? all other parts on engine?)
i did a www scan and in 1 second, bam the 4 banger
not the 4 liter.
2.5L gas engine not the diesel of same size.
so...
1984 to 2002 run (all year run lenght) not an answer.
http://en.wikipedia.org/wiki/AMC_straight-4_engine
what does FIT mean.
to the mounts, the transmission, all will
pass smog
be legal, say in CALIF? (strict year codes there.... btw)
make EFI happy (fit)
just the block, short block or just a naked block. you never said./
key fact on bell housing
Instead of the standard AMC bell housing bolt pattern, AMC/Jeep engineers adopted the General Motors small V6 and four-cylinder bolt pattern
short answer, all years fit, the short block.
In 1986 the head went under a minor revision, the head bolts were increased from 7/16 to 1/2 inch.
id bet that be lowest year.
http://www.allpar.com/mopar/amc-25.html
any with 1/2"head bolts
here is a nice page. google hits are free. huh?
http://engineguy.com/jeep-dodge-chrysler/2-5l-1.html?dir=desc&order=name
crank snout?
oil bypass
head bolt sizes
for sure the best answers are at all the top engine builders pages.
never on ebay. avoid them for facts.
you need a 530 block.
shop for that.
Apr 20, 2014 | 1998 Jeep Wrangler
Standard bore size mm
ENGINE 2 stroke single cylinder direct reed valve crankcase induction Liquid cooled 125 cc engine Cylinder size 124 8 cc Bore and stroke 54 x 54 5 mm 200 cc engine Cylinder size 175 3 cc Bore and stroke 64 x 54 5 mm 250 cc engine Cylinder size 247 7 cc Bore and stroke 72 5 x 60 mm 280 cc engine Cylinder size 272 2 cc Bore and stroke 76 x 60 mm 300 cc engine Cylinder size 294 1 cc Bore and stroke 79 x 60 mm I Cant put periods or commas so bare with me
Mar 15, 2014 | 1999 Daewoo Lanos
Pcm ign fuse
Either in the fuse block, or in the engine compartment fuse block! Interior fuse block, now bare with me here... is on one side of the dash, behind the kick panel, or behind the glove box!
Sep 04, 2013 | 2000 Oldsmobile Silhouette
When u purchase a new 6.2 litre bare engine block dose it come with an engine identification number already stampd on it
not sure for holden in australia but here in the states a new gm short block will be stamped and we have to keep track of the new number at the dealer when its changed
Jan 12, 2013 | Cars & Trucks
When car is started the radio brings engine noise and revs through it
Hello! The 1994 and later model Grand Am's are well known for radio interference...Technical Service Bulletins (TSB) have been written by GM without solution...If you have a multimeter...set it on the X1 ohm scale...Place one meter probe on the center of the negative battery cable and the other on bare metal of the chassis (a fender bolt)...Must read zero ohms...Move probe from chassis to engine block...Must read zero ohms...If you do not obtain readings close to zero ohms, run 8 gauge wire from negative battery post to bare metal on the firewall or body bolt...Also run a 8 gauge wire from chassis to bare metal on the engine block...If this does not correct the problem visit any audio shop and purchase a noise filter...Instructions are included...Guru...saailer
Dec 26, 2010 | 1994 Pontiac Grand Am
My Audi 3.2 2008 A6, 32k miles, has had major oil issues. Now Audi wants to replace the engine with a remanufactured engine, short block. Should I take it or tell them to buy it back?
yes you can go for that ha bare engine, that would be better , audi wants to replace that cause it may cost you all most same to repair it, so they want to replace it with new bare engine.
Jan 27, 2010 | 2008 Audi A6
Need to now what size this block is
the engine block itself will have the motor size on it
Jun 14, 2009 | 1988 Chevrolet K2500
Engine 2.2 dci
Yes the bare blocks are the same.
Please rate this solution.
Jan 16, 2009 | 2001 Renault Sportwagon
Vehicle Parts & Accessories Logo
48 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
