Question about Miele T9820 Gas Dryer
Miele dryer doesn't stop
I had to pull the plug to stop it.
    Genius:
  • 1,224 Answers
Stuck buttons have tech inspect
Posted on May 17, 2014
Dryer keeps stopping cycle
The most common cause of the error is lack of airflow. Check the exhaust output and see if it is restricted, you may have to check the venting in the building and unhook the dryer from it to check and see. If it runs unhooked from the exhaust system then it is a venting issue. IT could also be plugged lint screen, loose fan motor or obstructed fan. If it is not any of those then it is the thermal sensor or thermostat that is bad.
Jul 09, 2013 | Miele Dryers
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
DRYER STOPS/STARTS DOESN'T GET HOT ENOUGH
dryer duct blockage caused thermal limiters to trip. four t 20 screws remove the heater bank cover on the back of the dryer. unplug the dryer. unplug the dryer. did i forget to mention, unplug the dryer? remove the heater bank cover, and press the three red buttons in the center of each thermal limiter. at least one of them should click when you press it. replace the cover, plug the dryer in. it will now heat, but if you dont fix the blockage it will trip again.
Jun 14, 2012 | Miele T9800 Electric Dryer
Miele dryer starts and stops after a minute
Your digital control board may have a bad circuit and needs to be replace
Dec 30, 2011 | Miele Dryers
Hi, My dryer does not get hot anymore. its blows cool and takes 3 hours to dry now. any suggestions. Clint is clean and not blocked also
Our Miele 9800 dryer didn't heat and we called the service technician from Miele. Our thermal elements needed to be reset. Pull the plug before you do this. Take off the small back panel with a phillips screwdriver. Reset the the three thermal elements. Put the cover back on, plug in and try again. A Miele is like owning a Mercedes Benz or a BMW. This is a high technology German product that needs attention at times.
Jul 18, 2011 | Miele T9800 Electric Dryer
The dryer doesn´t work
I had the same problem with my dryer. The Miele technician came and took a look at it. There was nothing wrong with any parts. My vent pipe was kind of crumbling, so he replaced that. He then scrubbed and washed the lint filter with dishwasher soap and
the green scrubber, He also did a PC update of the firmware. My
unit already had the latest version, but he did erase all the error codes.
After all these rather simple steps the dryer started working like a charm.
He said the most probable caused was gummed lint filter because of using the dryer sheets. Miele dryers are designed to prevent static cling and he advised not use these sheets as they contain wax-like substance.
I would suggest scrub cleaning the lint filter first and see if that helps.
Aug 02, 2010 | Miele T9820 Gas Dryer
Clean filter / vent indicator stops unit after T9820 MIELE GAS DR
Call Miele and schedule a PC update. When the technician comes he will do the update, if needed, and will reset the error codes.
Apr 04, 2010 | Miele T9820 Gas Dryer
Dryer stopped and died. Power is still on but all lights are off.
no,check power at house panel and again at dryer plug for 240 volts
Aug 29, 2009 | Miele T9800 Electric Dryer
Miele T9820 Gas Dryer Logo
64 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
