A solution of NaOH has a concentration of 3.02 X 10 2M what is the pOH of this solution?
Nokia 6103b rm 162locked
PANO POH MAG REPORMAT NG CHEERY MOBILE t18 NG HUHUNG POH EH PANO POH
Dec 07, 2013 | Cell Phones
Explain the relationship between pH and relative concentration of hydrogen and hydroxide ions in a solution
The pH scale is a logarithmic scale used to measure the concentrations of hydrogen/Hydronium ions in an aqueous solution.
If c[H] is the concentration of hydrogen ions in mol/L, the pH is defined as
pH=-log(c[H]).
Inversely, the concentration is given by
c[H]=10^(-pH)
The pOH=14-pH
Jan 19, 2012 | Office Equipment & Supplies
Hndi poh ako mka connect s wap internet poh..lht n poh gnwa ko n
Hi, anong phone ang gamit mo? . baka kailangan mong mag download ng settings galing sa sim mo.
Thank you.
Sep 13, 2011 | Computers & Internet
How to fix the critical error in idate of gameclub.ph plz help me i really like dis game
Di ko poh maaus ang iDate ko panu poh ba e2 kahit anung gawin ko poh ayaw talaga Favorite ko poh ang iDate plsss panu poh ausin ang iDate ko Laging nag cri-critical error khit anung launcher poh ayaw
May 18, 2011 | Computers & Internet
It is required to prepaire 100g of a 27.5% by mass solution of NaOH.calculate the nf of solution of NaOH.
I am going to assume your term, "nf," which I do not recognize as an acceptable unit of the metric system, is meant to be molarity (M). So, it seems to me that you are asking for the molarity of the solution that is indicated in the problem.
To calculate the molarity of the solution of NaOH in this problem, one must apply the ratio, moles per liter of solution, the definition of molarity (moles/L).
A 27.5% solution means (27.5 grams) / (100 grams of solution), which in this case is equivalent to
27.5 g / 100 mL solution, because the density of water is 1.00 g/mL.
Since 100 g solution is specified, that means there are 27.5 g of NaOH in the solution (100 mL volume, or 0.100 L).
Moles of NaOH in solution = [27.5 g NaOH / 40.0 g mol NaOH/ mol NaOH] = 0.688 mol NaOH.
Therefore, molarity of NaOH = mol NaOH / L = (0.688 mol NaOH / 0.100 L) = 6.88 M NaOH.
Jun 02, 2010 | Scientific Explorer My First Chemistry Kit
I trying to work out how to use my ti83 plus -What is the pH and pOH of a 1.2 x 10 -3 HBR solution?
First you have pH+pOH=14
Thus pOH=14-pH.
The problem with you question is that you do not specify the meaning of the 1.2 x 10^(-3). Is it the molar concentration of the hydrpbromic acid HBr.
I am going to answer your question but I must make some assumptions. You can imitate the reasonning to obtain your answer, once you have decided or looked up what the numbers mean.
Lets assume that HBr concentration is 1.2x10^(-3) mol/L. Since it is a strong acid, it dissociates completely, releasing 1.2x10^(-3) mol/L H+/H3O+ ion.
Thus the pH is
pH=-log(1.2x10^(-3)).
The result is 2.92
Here is a screen capture of the actual calculation. The minus signs are the change sign (-) to the right of the dot. To enter the power of 10 (represented by the E in display) use the (2nd)(EE) key sequence. To access the content of (Ans) memory, press (2nd) (change sign)
Mar 07, 2010 | Texas Instruments TI-83 Plus Calculator
Cannot figure out how to use the reverse log on my Staples Textbook display BD-6410 Calculator the pOH is 6.59 I need to use the reverse log to get the answer for the H+ which is the reverse log of 6.59...
You should use the equivalence
y=10^(x) is equivalent to x=log(y)
You should not use word that have no meaning. x above is sometimes called antilog, not reverse log.
The relation linkin pH and pOH is as follows
pH+pOH=14, thus pH=14-pOH
Let c[H+] be the concentation (or if you use the hydronium ion, instead of H+ ) c[H3O+] the concentration of hydronium ion)
c[H+]=c[H3O+]=10^(-pH)
pOH= 6.95 thus pH=14-6.95 = 7.05
If pH=7.05 the c[H+]= 10 ^(-7.05) =8.9125E(-8)
pH= 10^ [X to the power] [(-)]7.05
The key/buttom to raise to the power is the one to the right of x squared
Hope it helps
Sep 10, 2009 | Texas Instruments Office Equipment &...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
