Question about Panasonic PanaFax UF-8000 Laser Fax
WHAT IS ERROR CODE 401 - Panasonic PanaFax UF-8000 Laser Fax
Error code 401
Sounds like you are probably messing up the username and password.
"Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.)."
www checkupdown com status E401 html
Mar 14, 2014 | Facebook Computers & Internet
It always said to me error 401
Error 401 means that you can't access a web site. To fully understand the error and how we need to try and help you fix this we need to know what HTTP Error 401 - you are getting.
Example: HTTP Error 401 - Unauthorized: Access is denied due to invalid credentials.
Feb 24, 2011 | Computers & Internet
When i update my panda internet security 2010 i take an error code 401 i have windows vista home premium
The error code 401 is due to a conflict in Vista's virtualization system. Here's how to fix this: Click on the Windows logo at the bottom left (Start), write APPDATA in the text box and click Enter. On the window that will open go to the Local > Virtualstore > Program Files. Delete the folder called either Panda Software or Panda Security. Open the antivirus. Enter your update details again and update your security solution.
Jan 28, 2011 | Encore Panda Internet Security 2010 3...
Hello, I've got a problem with error code 401 when panda internet security 2009 (license up 3 pc's) is traying load update from internet, my license is active until 01.2011,thenks
The error code 401 is due to a conflict in virtualization system. Here's how to fix this: Click on the Windows logo at the bottom left (Start), write APPDATA in the text box and click Enter. On the window that will open go to the Local > Virtualstore > Program Files. Delete the folder called either Panda Software or Panda Security. Open the anti-virus. Enter your update details again and update your security solution.
Aug 15, 2010 | Panda Internet Security 2009 - 3 User for...
What should I do when 401 unauthorized is happened?does it have any relationship with my modem? best Regards
401 error: Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.).
Are you trying to access your modem's gui?
additional info/reading:
http://www.checkupdown.com/status/E401.html
Aug 09, 2009 | ASUS Computers & Internet
Hello, I have a machine Ricoh Aficio 5470 that each 30 copies that it prints begin to clog the leaves between the cylinder and the band of transference, and after a pair of cloggings throws the code to me...
could not find model 5470, however a SC 401 on all models is transfer leak error, meaning you need to replace the transfer roller (or more realistically have a trained technician replace it) this should solve your issue, if there is no maintenance on your your machine it will cost you between $200- $300 in parts and labor
Jun 22, 2009 | Office Equipment & Supplies
Keep getting a 401 unauthorized code when trying to log in to sur
Your Web server thinks that the HTTP data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) was correct, but access to the URL resource requires user authentication which 1) has not yet been provided or 2) which has been provided but failed authorization tests. This is commonly known as "HTTP Basic Authentication". The actual authentication request expected from the client is defined in the HTTP protocol as the WWW-Authenticate header field.
401 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
Open an IP socket connection to that IP address.
Write an HTTP data stream through that socket.
Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code it recognises as '401'.
Fixing 401 errors - general
Each Web Server manages user authentication in its own way. A security officer (e.g. a Web Master) at the site typically decides which users are allowed to access the URL. This person then uses Web server software to set up those users and their passwords. So if you need to access the URL (or you forgot your user ID or password), only the security officer at that site can help you. Refer any security issues direct to them.
If you think that the URL Web page *should* be accessible to all and sundry on the Internet, then a 401 message indicates a deeper problem. The first thing you can do is check your URL via a Web browser. This browser should be running on a computer to which you have never previously identified yourself in any way, and you should avoid authentication (passwords etc.) that you have used previously. Ideally all this should be done over a completely different Internet connection to any you have used before (e.g. a different ISP dial-up connection). In short, you are trying to get the same behaviour a total stranger would get if they surfed the Internet to your Web page.
If this type of browser check indicates no authority problems, then it is possible that your Web server (or surrounding systems) have been configured to disallow certain patterns of HTTP traffic. In other words, HTTP communication from a well-known Web browser is allowed, but automated communication from other systems is rejected with an 401 error code. This is unusual, but may indicate a very defensive security policy around your Web server.
Fixing 401 errors - CheckUpDown
When you set up your CheckUpDown account, you may optionally provide two items 2. Web Site User ID and 3. Web Site Password. You should provide these only if your site uses HTTP Basic Authentication. If you provide them, the CheckUpDown robot always uses them. This will result in a 401 error if in fact your site does not use this authentication. Conversely, if you do not provide them and your site does use this authentication, you also get a 401 error.
If however your URL is open to all comers, then an 401 message should not appear. Because it indicates a fundamental authority problem, we can only resolve this by negotiation with the personnel responsible for security on and around your Web site. These discussions unfortunately may take some time, but can often be amicably resolved.
Alternatively or the other way around is :
open the XP hosts file, and do a manual insert there.
The hosts file is located at: C:\WINDOWS\system32\drivers\etc
The entry is: 192.168.0.1 www.routerlogin.net
You might need to flush your DNS records at this point, or simply restart your computer.
And then use the following URL to access the admin page:
http://www.routerlogin.net/setup.cgi?next_file=start.htm
***Here is another solution to the problem, which is a fairly straight-forward way to disable the annoying wizard.
Type in your browser:
http://www.routerlogin.com/CA_HiddenPage.htm
Select: Disable Configuration Assistant, and click on Apply.
You can re-enable it by navigating to http://192.168.0.1/CA_HiddenPage.htm (where 192.168.0.1 is your router’s IP address)
Apr 11, 2009 | NetGear WGR614 54Mbps Wireless Router...
When faxing a 401 error is reported
error 401 means that your number is not programed in the machine you are trying to , so it blocks it
Jan 21, 2009 | Panasonic Workio DP-190 Multifunction...
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
Panasonic PanaFax UF-8000 Laser Fax Logo
47 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
