Question about Amcor AF9000E Portable Air Conditioner
Duct connector for CF14000E
Need a duct connector
Is there a service manual for amcor CF14000e air conditioner?
The air conditioner should have the manual with it. If you are in a rental, the owner may be able to provide it on request. Once, in a rental, I found all the appliance manuals in a drawer in the kitchen. If you can't find it, you can order one from the customer service department whose phone number should be on the conditioner itself.
Elisa Jed ' http://www.confortexpert.com/Air+conditioning
Aug 19, 2014 | Heating & Cooling
Removing low beam bulb on 05 subaruoutback
Whether they become damaged in an accident or simply burn out over time, your Subaru Outback's headlights may eventually need to be replaced. Fortunately, once you've purchased the right replacement bulb for your model year, performing the repair yourself is relatively easy. These instructions only apply to Outback models made after 2000.
  1. Undo the clips on the air intake ducts using a screwdriver and remove the duct from the engine compartment (driver's side bulb removal only.)
  2. 2
    Loosen the secured clip on the washer tank with a screwdriver and slide the tank horizontally to allow easier access to the headlight assembly (passenger's side bulb removal only.)
  3. 3
    Turn the bulb cover counterclockwise and remove it from the assembly.
  4. 4
    Disconnect the headlight electrical connector and undo the assembly retaining spring.
  5. 5
    Pull the old bulb directly out of the socket and replace it with the new one. Press the retaining spring back into place and reattach the electrical connector.
  6. 6
    Replace the bulb cover, and then turn on the engine. Test the new headlight to make sure it works before replacing the air intake duct or the washer tank and closing the hood.
    Replacing the High-Beam Bulbs
  1. 1
    Undo the clips on the air intake ducts using a screwdriver and remove the duct from the engine compartment ( drivers side bulb removal only.)
  2. 2
  3. 3
  4. 4
    Turn the headlight bulb counterclockwise and pull it out of the socket.
  5. 5
    Reinstall the new bulb, replace the retaining spring and reconnect the electrical connector.
  6. 6
Sep 14, 2012 | Cars & Trucks
Replacing blower motor resistor on 2001 BMW 325i.
Look for a 5 wire connector coming out of the heat duct on the center passenger side usally there is 2 screws that hold it against the heat duct..Before you replace it i would check for a bad connection by turning the ignition and fan switches on and pull on and wiggle the connector if its just a bad connection then it should start working.
Jan 19, 2012 | Cars & Trucks
Need a service manual (not a user's manual) for Amcor CF14000E
THEY WENT BELLY UP TWO YEARS AGO.WwHAT TYPE OF INFORMATION ARE YOU LOOKING FOR ?
Aug 26, 2011 | Amcor Heating & Cooling
Hi to all i have canon ir6570 model my problem is E824-001 it seems that the primary cooling fan working properly could someone describe the wiring connection of the primary cooling fan
Most likely the primary cooling fan connector has been left unplugged. Open the front door and look under the control panel just to the left of the filter. There will be a gray cover that will have to be removed. This covers the connector to the fan. Remove the cover and check to see if the fan is plugged in. If this is correct then unplug the fan connector and then go ahead a remove the two other screws on the duct on the far right side. Remove the duct and make sure the fan is plugged in to the duct connector. Never had any other problem further in the fan wiring than that.
Apr 06, 2011 | Canon imageRUNNER 5570 Copier
How to change airfilter in 2003 oldmobil shiloutte premier van.
Loosen the 2 air cleaner intake duct clamps from the Mas Airflow sensor and the throttle body. Disconect Intake Air Temperature sensor connector.
Disconnect the vent tube from the air cleaner intake duct. Disconnect Mas Airflow Sensor electrical connector. Unlatch the air cleaner cover clips and remove the air cleaner intake duct and air cleaner cover.
Change the filter and reinstall.
Mar 17, 2011 | 2002 Oldsmobile Silhouette
Truck does Not Start, No Spark to coil replaced Coil, All spark plugs and wires and battery still doesnt start Tryed using a code reader shows up No codes, Possible Problems?
Ignition Module REMOVAL & INSTALLATION The engine controller is the computer/microprocessor that regulates all ignition functions. All other models (1989-96) employ a 60-way connector. The 1989 models (only) employ an additional 14-way connector. In most cases, the engine controller is mounted in the engine bay to the firewall or a fender. Some early models mount the engine controller in an air duct mounted on the inside left fender. Access to these units hidden in the air duct requires some dismantling of the air duct to get to them. WARNING
Do not remove the grease from the 14-way connector or the connector terminal in the computer. The grease is used to prevent corrosion of the terminals. There should be at least a 1?8 in. (3.1mm) coating of grease on the bottom of the connector terminals. If not, apply a liberal coating of Mopar Multi-purpose grease No. 2932524, or equivalent, over the entire end of the connector plug.
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner duct from the controller, if equipped.
  3. Remove the three module retaining screws.
  4. Remove the 14-way (1989 models) and 60-way connectors from the controller. NOTE: Check the 14-way and 60-way connectors for damaged or bent pins (and correct if any are found) prior to plugging it in.
  5. Installation is the reverse of removal.
Oct 13, 2010 | 1996 Dodge Dakota
I have Jaguar XJR 2001. How do I replace Blower Motors Left and Right side? ( Noise bearing )
Driver side :
1- Remove upper steering column 2- Remove driver stowage compartment 3- Remove driver's footwell duct 4- Remove cable tie 5- Remove duct connecting blower assemble to heater/cooler unit 6- Disconnect harness connector from blower assembly 7- Remove blower assembly.
Install in reverse order. Tighten nuts to 5-7 Nm
Passenger side :
1- Remove Instrument panel 2- Remove passenger footwell duct 3- Disconnect harness connector from blower assembly 4- Remove festeners securing duct to heater/cooler unit 5- Remove duct connecting connecting blower to heater/cooler unit 6- Remove blower assembly
Sep 11, 2009 | 2007 Jaguar XJR Sedan
I need to install an evaporator core in 1997 xj6. Any tips or suggestions?
Ok , I will try to guide you as simple as I can :
1- Remove the Heater / Cooler unit this is how : * Disconnect Battery ground cable
* Recover AC gas or empty it in open space
* Drain radiator coolant only
* Remove instrument panel for access
* From under the hood disconnect AC pipes at the evaporator , by removing bolts , discarding O-Rings and make sure to install blanking plugs so that no dirt goes in.
* Disconnect heater hoses from heater matrix pipes , by releasing the spring band clips and make sure to blank the pipes
* From inside the car , remove driver footwell duct , by removing the screw and then removing the duct
* Remove upper steering column lower fixing , nuts and bolts
* Remove upper steering column upper fixings (Bolts) , and allow column to rest down o the floor
* Cut cable tie which secures console harness to LH blower duct
* Remove LH fan motor duct (screws)
* Remove passenger side footwell vent (nut)
* Cut cable tie securing console harness to RH blower duct.
* Remove RH fan motor duct (screws)
* Disconnect Heater/Cooler Connector
* Disconnect drain tubes from Heater/cooler assembly
* Disconnect A/CCM connectors
* Remove evaporator pipe support bracket fixing.
* Remove Heater/Cooler assembly fixing , by removing lower nut and upper nut
* Remove tape securing RH rear footwell intermediate duct joint. Remove duct to clear access
* Remove tape securing LH rear footwell duct
* Remove Heater/Cooler assembly from car.
2- Remove AC control module 3- Remove evaporator pipe seal plate 4- Disconnect heater tempreture sensor 5- Remove footwell servo motor from heater/cooler unit * Disconnect connector
* Remove screws
* Remove motor complete with bracket
6- Disconnect evaporator sensor connector * Detach heater/cooler connector
* Detach evaporator sensor connector
* disconnect connector
7- By now you can see one upper and one lower case * Remove heater/coolent unit upper case from lower case
* Remove screw
* Remove 15 clips
* Remove upper case from lower
8- Remove evaporator from case * Remove sensor and clip
You are done , make sure to replace all seals that you see to make sure that every thing is ok and you do not have any leaks after installation.
Installation : Reverse order and after installing make sure to do a pressure test to make sure that there are no leaks
Jul 12, 2009 | 1997 Jaguar XJ6
Amcor AF9000E Portable Air Conditioner Logo
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
