Question about Vizio Televison & Video
I have a VBR120A_3_3_014_VBR_19_03 vizio blu_ray player that is wired only. I have a phone line connected from the BLU-Ray player directly to the wall. How do I find my Ip address (which currently shows as 0.0.0.0) so I can manually configure?
SOURCE: blu ray disc will not play in vizio vbr110 player.
i feel your pain, i have the same player and the same BD wont play past the menu! i dont have a solution for this problem... but if u find a solution... email me at brt.brt.brt@hotmail.com thanks
Posted on Feb 13, 2010
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
  • 15 Answers
SOURCE: need a user manual download for vizio blu-ray
Here ya go:
http://70.168.148.201/documents/downloads/accessories/VBR120/705VBR120%20User%20Manual%20Rev1.pdf
http://www.vizio.com/home-theater-1/vbr120.html
Posted on Mar 14, 2011
SOURCE: When I try to update
unlock server error 11000404 on a vizio blu ray vr210
Posted on May 14, 2011
SD Tech
  • 14553 Answers
SOURCE: Sharp Blu-rAy player won't play Blu-ray discs but
Due to the nature of players often if the optical Pickup unit inside is dirty or failing Blu-rays will not play but DVD's will.
Posted on May 06, 2012
My Vizio Vbr 220 wont play Videos from my usb
MP4 or AVI files will definitely work but make sure your USB memory is formatted in FAT32.
Aug 14, 2015 | Vizio VBR220 Blu-Ray Player
What is flashing yellow light on back?
does it have a wired ethernet port in the back? If it does that is the light that is flashing.The digital sound should have a small cover over it that prevents you from seeing the light it emits.
Jun 05, 2014 | Vizio VBR220 Blu-Ray Player
I have a vizio vbr 2011 wireless blu ray player. im unable to connect it to my arris dg860p2 routor. please help
i presume you mean a VBR210.
Both the player and router use 802.11N at 2.4GHz so they are compatible.
Check the security on the router that it does not require MAC addresses.
Check the firewall, DHCP and parental controls on the router
Try a hard cable to see if that works.
Most smart units will not setup WiFi if you have a network cable plugged in.
Try both the press button and manual PIN methods to connect the player
See the manual pages 20-22
Good luck
May 28, 2014 | Vizio VBR210 Blu-Ray Player
Vbr 231 updates
If you go into the "settings" option and look under "info" it should show your current softwareicon1.png version. The most recent update is VBR231A_3_3_035_VBR_36_01 from December of 2011. there haven't been any releases since then, unfortunately. There doesn't appear to be any sites or mirrors to download this update. Usually, these errors are due to a lack of content available for download.
Apr 01, 2013 | Vizio VBR231 Blu-Ray Player
Vizio vbr 333 firmware update
http://cdn.vizio.com/documents/downloads/accessories/VBR120/VBRFW_Instructions.pdf
Dec 23, 2012 | Vizio 3d Blu-ray Player With Wireless...
How to register my new vizio Blu-Ray Player
Usually can be done by mail or on the site as indicated with the paperwork that came with the unit.
Apr 29, 2012 | Televison & Video
My Vizio VBR-100 Blu-Ray Turns on once connected to the wall outlet, but does nothing else like showing any thing on the tv input. Why?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 21, 2017 | Vizio VBR100 Blu-ray/HD DVD Player
I have a vizio blu-ray player vbr120a. I can't seem to see or setup the wireless capability with the player. does it exist? no instructions in the box, but downloaded the manual. thank you
The VBR120 has no native wireless capacity; it only has wired ethernet built in.
I do not see the VBR120A anywhere on the Vizio Site.
I wish that I had better news for you.
Aug 08, 2011 | Televison & Video
Need a user manual download for vizio blu-ray player, model-vbr 120.cannot find in listing. the quick stard manual says it can be downloaded.
Here ya go:
Mar 14, 2011 | Televison & Video
Televison & Video Logo
16 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
