Sxx sxy sxy - Audio Players & Recorders
My Maxtor SXX wont read as the master drive
Check jumpers on back of drive. If they are jumpered as slave it will Never show as master.
Oct 02, 2014 | Computers & Internet
How to hook up dual voice coil sub
Two things I need to know
1 Make and model of Amplifier you intend to use
2 Is it going to be a single sub or 1of a pair
May 02, 2014 | Re Audio Sxx12 12" 1000w Rms Sxx Car Sub...
Workcentre Pro 245 shows an "Internal Power Supply Failure". We just got the machine and it tested OK. We moved it carefully and tested it again OK. But an hour later, it showed this error...
There are 4 solutions to try and they don't fit in their entirety so I included links to each one. Please be sure to read the instructions entirely AND ensure you need to perform each one.
1. Power machine on and off http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4322)
2. Clean the Charge Scorotron and the Transfer Corotron: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4186)
3. Perform a Software Reset at the Printer: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(5315)
4. Replace the Xerographic Module and Transfer Unit: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(3362)
If none of those fail to resolve it call for service.
Hope it helps!
Mar 08, 2011 | Xerox Office Equipment & Supplies
Windows XP on a Versa SXi
It meets the MINIMUM...
it will be slow runing XP
but the answer to your question is Yes you can put XP on your PC...
Matt
Jan 23, 2009 | NEC Versa SXi Notebook
1.2 vauxhall corsa sxi im looking for the hole so i can feed electrick from the batt to a ammp located in the boot were is it please help
the hole is under the glove compartment pierce a hole through that rubber circle big enough to fit the wire through
Jun 27, 2008 | Car Audio & Video
48 people viewed this question
 Grubhead
Grubhead
