Sharp AL-2040-Need to know how to make the energy
Need to know how to make the energy saver time longer. They want it to stay on all day.
  • 143 Answers
NOT recommended to stay on all day.
Posted on Jul 07, 2009
I'm considering a Canon D340 multi-function copier and notice it has an "energy saver" button rather than an on/off switch. After making a copy, the panel goes dark. If you select the "energy saver"...
There is still power to the machine. It is simply waiting to be used. These machines use an "instant on" fuser. These fusers (the part that heats up to fix the toner to the paper) do not use a heater lamp that needs to stay hot. They use a thermal head that can heat up within a few seconds so no need to stay on and hot all the time.
Jan 07, 2010 | Canon PC-D340 All-In-One Laser Printer
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Is there any way to turn off or adjust the energy saver mode?
This is done easy - here is the link to the operation manual for this machine. Go to page 55 of the manual (page 57 of the PDF document) and it explains it all. http://www.sharpusa.com/files/cop_man_soho_AL1642CS.pdf
Problem solved.
Apr 03, 2009 | Sharp AL-1642CS Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
Sleep mode
Needs the firmware ( machine operating software) updated to the newest level.
Mar 18, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Do not know how to use the energy saver feature
i have a problem for minolta di351 by code c009 pls help me
Feb 21, 2009 | Toshiba e-Studio 350 Copier
Copies
I can't remember but there should be a button with the name above it No. of Copies press this then you will be able to enter 1-99 copies. The energy saver you can adjust within the menu to longer or not come on at all. This will be in your manual.
Thanks J
Jan 10, 2008 | Sharp AL-1655CS Laser Printer
Energy Saver
On most copiers, you can't totally disable it... it's all part of that "energy star" rating thing. It's annoying, i know.
Jan 09, 2008 | Toshiba 2060 Copier
Lg 10000 btu ac wall unit
if you remove the front cover you should see a little sensor with a wire. you need to make sure it has not fallen off its bracket or came off form the evaporator. if it looks to be ok and mounted correctly, you may have a bad sensor and it is not able to tell the temp and not shut the unit down. also to on very hot and humid days even though you have it set to energy saver it senses it still needs to run. If you turn the thermostat up when its on the energy saver will it shut off? and if you do the same on the regular setting will the comressor shut off and the fan stay running? Let me know and I can go from there. Thanks
Aug 05, 2007 | LG Electronic Window Air Conditioner
44 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
