Question about LG WM2140CW Washer
Water remaining in the detergent cups - LG WM2140CW Washer
2 Suggested Answers
  • 4 Answers
SOURCE: Water remains in the liquid detergent cup
If you have excess water in the tray, close the water supply valves a little. Front load machines can have issues with improperly regulated water lines (Water pressure may be above reccomended specifications).
Posted on Aug 09, 2009
What can I use to remove a stain of SOYSAUCE in a carpet?
Carpet
1. Mix one tablespoon of liquid hand dishwashing detergent with two cups of warm water.
2. Using a clean white cloth, sponge the stain with the detergent solution.
3. Blot until the liquid is absorbed.
4. If the stain remains, mix one tablespoon of ammonia (Caution: Never mix chlorine bleach and ammonia - the resulting fumes are hazardous) with 1/2 cup of water.
5. Sponge the stain with the ammonia solution.
6. Blot until the liquid is absorbed.
7. Sponge with cold water and blot dry.
Nov 21, 2014 | Heating & Cooling
10-yr old GE Profile dishwasher...lately there's been detergent left in the cup, and lots of items come out dirty...plastic, ceramic, etc. I've cleaned/rinsed the sprayer and filter, but it doesn't he
Check if the water is getting heated in the dishwasher. Most likely water temperature if not adeqaute will not fully use the detergent and cause dirty dishes. This could be caused by heater which is failing.
Apr 19, 2014 | GE 24 in. Profile PDW7800 Built-in...
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
I recently purchased a insinger 18-5 dishwasher, what type of detergents should I use ??
Follow the steps below to ensure proper dishwasher detergent selection and usage.
Use only powder, liquid or tablet detergent designed specifically for automatic dishwashers. Any other types may cause a sudsing and as a result, poor wash performance and possibly suds and water on your kitchen floor. GE recommends either Electrasol®, Cascade® or Cascade Complete® detergents.
Use the right amount of detergent for the job. Soft hot water requires less detergent - perhaps a quarter of a cup in the main cup. Very hard water requires a full main cup and a full open cup to get good wash performance. Conditions between these require judgment. Use enough to get the job done, but don't use more than you need.
Too much detergent in very soft water will cause etching of glassware. This is a permanent clouding of the glass. If you experience this condition, use less detergent.
Keep your detergent fresh and dry. Store the detergent in container away from moisture to prevent lumps. Do not put detergent in the cup until you are ready to run a cycle. If powder detergent gets old or lumpy, throw it out; it will not clean effectively. Liquid detergents do not age.
As a rule of thumb:
Harder water requires more detergent
Cooler water requires more detergent
Softer water requires less detergent
Hotter water requires less detergent
Jun 15, 2011 | Singer Commander 18-5 Dishwasher
The soap does dot dissolve
assuming you are using the correct dishwasher detergent type and quantity recommended for the dishwasher, the likely cause for detergent not dissolving is that the water is not circulating well enough through the wash arm. Check the wash arms are clean. Do dishes come out clean? Run the dishwasher with a cup correct side up on the top rack. If it is empty at end of wash then there is no water in the top arm.
Is the detergent dispenser door open during wash cycle?
Also lack of adequate wash water template can cause detergent to remain undesolved. Hope this helps.
Feb 15, 2011 | Asko D1796FI Built-in Dishwasher
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
My LG WM2487H has water in the detergent cup at the end of the wash. It has happened twice now.
This is normal.
All LG washers use a siphon system to dispense soap, bleach and fabric softner.
Some times water will remain in the cups depending on the cycle used.
Jan 20, 2010 | LG WM2487H Front Load Washer
The place where u place the soap won't let all the soap out why
hello. i can help you.
When the detergent cup doesn't open, check these:
Timer
Bi-metal switch or wax motor
Detergent cup, itself
Timer On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards.
The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it.
On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly.
Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door.
Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
Jul 05, 2009 | Electrolux Kenmore 24 in. Built-In...
This is by design. Water flows in and forces the detergent out. There will almost always be a little water left in the cup after a wash routine.
Jun 15, 2009 | LG WM2487H Front Load Washer
Dispenser problems
Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
Oct 18, 2008 | LG WM-2277HW Front Load Washer
LG WM2140CW Washer Logo
13 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
