Question about Yamaha Audio Players & Recorders
I have very limited sound coming out of the right speaker outputs (both A&B) I have. swapped the speakers to make sure it was not the speakers. It has worked fine for a year, the problem just started.
  • 4 Answers
What kind speaker do you have? what is the Ohms shoult say it in the back of the speakers and how many speakers do you have in each outputs?
Posted on Jun 24, 2009
Vox vth120 valvetronix No sound from left speaker output
Try swapping the Left and Right speakers with the following procedure, observing correct polarity of wires:
[i] Label both speaker leads and speakers first to avoid confusion with restoring to same configuration.
L and R is good enough, masking tape suitable.
[i] Swap entire driver / lead assemblies.
Does left channel still not work?
If so then problem is amp.
If fault now swaps to R ch then amp is ok - problem external.
Return to original L&R config.
[ii] Disconnect leads at speaker ends only (power off).
Swap drivers only so leads are still same L&R but drivers now R&L.
Power up and test.
L channel fault = lead or connector fault.
R channel fault = driver fault.
With a multimeter:
Check buzzer-continuity of leads + + & - - end-to-end.
Check ohms of speakers closely match specified impedance.
Dec 19, 2017 | Audio Players & Recorders
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
May 24, 2008 | Audio Players & Recorders
In my JVC RX 8SD only works a channel. How do I repair this defect?
Start with the simple things.
  • Check left right balance
  • Swap output speakers left to right
  • Swap the speakers at the receiver to make sure no wire open/short
  • Swap input RCA cables left to right red/white - white/red
Ok No JOY!
JVC has thermal overload circuits/overload on most of there Amps.
Remove power for a minute or two to see if there is a reset.
Rewire speaker connections to speaker set 2.
Connect REC out to Rec In swap cables and see if problem is in pre-amp or power amp.
Check internal fuses.
Jan 19, 2016 | JVC Audio Players & Recorders
I only have left channel on speakers working have tested speakers ok, swapped pre amp boards still one channel, swapped output boards the same. What could it be? Barry
is there Sound stage output is stereo if stereo then one side is missing or broken link from ic to speaker, If mono output then use with one side 2 speaker parallel.
May 20, 2015 | Audio Players & Recorders
No bass in righthand speaker
First try swapping the cables and put the left speaker cables in the right hand amp output and the right speaker in he left output. If the problem stays in the right hand speaker and does not move to the left as I suspect should, then it is a problem with your speaker crossovers. You may have to open up the speaker and check the wiring and then crossover. If the problem changes and appears in the left hand speaker you have an amp problem.
Jun 08, 2014 | Mission M73 Main / Stereo Speaker
Sparks from the speaker wire and no sound through the left just a hum
Audio output amp section circuit to your amp [left] has damaged. Check and replace damaged component/s there. The work will is a skilled one. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 11, 2014 | NAD Audio Players & Recorders
Why does only one channel volume work? I am pretty sure it worked when tested it before I bought it. I have both speakers hooked up and I have a mixer connected to the power amp. Thank you
The 'problem' could be anywhere in the chain - amp, mixer or speaker. YOU need to do some swapping to isolate which product failes. Swap channels, inputs and outputs and speakers.
Jul 21, 2011 | Gem Sound EXA1955 Amplifier
Fuzzy sound from right front speaker output
The main issue is to determine where the distortion is coming from. Does it start in the front and and get amplified or does it appear in the output section only? This will require a fixed signal and an oscilloscope to trace. Check for leaky coupling caps or leaky transistors in at the diff-amp section.
Dan
Feb 02, 2009 | Sony STR-DE485 Receiver
No Sound Right Front Speaker
Sounds (forgive the pun) like that channel's power chip is gone. Take it to a Tech, I may advise...
Mar 29, 2017 | Audio Players & Recorders
No sound
u gotta make sure all the connectors are right, The dvd player output cables are plugged into the OUTPUT of ur dvd, and they go into the Video Input of the amplifier, U gotta make sure ur speakers are plugged in into right too, out put speakers. Surround system only works on DVDs and some music CDS, so dont expext to have surround sound from all music CDS/
Feb 10, 2008 | Audio Players & Recorders
78 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
