Skin care blinking and shutdown after 3 blinks.
4 Suggested Answers
SOURCE: Shutdown & error led blinking 2 times
Shut off your projector by swith on the back near the AV inputs, leave it off for about five minutes. Then switch it back on, manually press the power button, let it start for about 5-10 seconds then continue to hold power button until picture appears. It worked for me, good luck to all.
Posted on Aug 14, 2009
TV #1
  • 129 Answers
SOURCE: shutdown power after 3 seconds.and
You need to replace the power supply board.
http://www.shopjimmy.com/panasonic-n0ae6km00001-power-supply.htm
Make sure the board is got the same number.
Thanks
Posted on Dec 11, 2010
SD Tech
  • 14553 Answers
SOURCE: HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
Posted on May 22, 2012
Is it a problem of the inverter board ?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 12, 2016 | Sony 40 KDL40BX420 LCD TV
Mitsubishi hdtv 1080 what are the blinking green light codes
ost models have a self-diagnosis feature to help determine shutdown problems.
To enable this feature do the following....
1) Turn the tv on and then let it shutdown
2) Press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds
3) After 5 seconds the power LED on the front panel will blink a two digit sequence.
This will commonly be one set of blinks followed by a short pause then another set of blinks.
This will repeat around five times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short detected - commonly caused by convergence failure - to repair this check out site for a convergence kit)
2 - 3 = Deflection protect
2 - 4 = Vertical protect
Note: A constant blink on certain models will typically be caused by a fault in the DM model. To repair this check out site a "blinking green light kit"
Aug 05, 2014 | Mitsubishi WS-55513 55" Rear Projection...
try cleaning the filter or run without one till you can replace it
May 16, 2014 | Heating & Cooling
Turn on power hear it come on then turns it self off and power light starts blinking
Blinking light may be a error code----look closely and see if blinks in a sequence---3 blinks, pause 3 blinks or 5,5.
The blinking light means set is in protective shutdown, Do you see a sequence to the blinks?
I am here to help.
If needed, unplug set and plug it back in and try to turn on---watch for likely error code.
SD TECH
Sep 17, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Turned on tv with remote (this turns on cable box and tv). TV came on for a few seconds and then went off, no picture, no sound. Remote would still change channels on cable box, so it is obviously the...
Most of these have a shutdown feature built in and if you unplug the set, plug it back in and turn it on manually look carefully at the power light on the front when you turn the set OFF.
It should blink a specific sequence: 3 blinks, a pause and 3 blinks etc.
3,3 and 5,5 are the most common and mean different things are wrong.
Let me know if you are able to see the error code.
SD TECH
May 11, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My tv wont tun on, the on button blinks red
PT-47wx53? This means the set is in shutdown---unplug the set and plug it back in and turn it on----when the power light blinks try to count the sequence---
for example___3 blinks, a pause and 3 blinks---it should repeat this several times---count carefully and let me know the number of blinks
3 blinks is the most common and the easiest to diagnose for repair.
let me know what you find, I am here to help people.
If this has helped you rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
Sony KV34xbr800 dead with 6 blinks
For 6 blinks Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.I think this will help you to solve the issue.
Dont forgat to Rate!!
Good Luck
Dals123
Oct 21, 2008 | Televison & Video
Hello
What that means is that the set doesnt recognize any shutdown error if it does 1blink short pause the 2 blinks, but if it does 2 blinks short pause the 1 blink thats an error code. can you dtermine which sereies of blinks it is?
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
