What dos f09 error means i have fagor fe 3611
4 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: What does a F09 error mean?
Since Sears doesn't manufacture its own equipment I need a product code number to access the specific features of your appliance. Email me with that info and I can find what the error codes are.
Posted on Sep 10, 2007
hwy505
  • 7 Answers
SOURCE: Error code F09 for HE3T Kenmore waher
Shannabug is right on the money. I had the same problem a few days ago. F09 came up - I hit pause twice - since there was water still in the drum I did a spin and drain.
NOW UNPLUG THE WASHER!
Right below the kickboard there are three torqux screws - now's a good time to get a Torqux folding key set. Once removed - give the side of the kick board a rap on the side - sometimes you may have to use an object to hit it with - it'll fall right off.
On the bottom, dead center is a white cylinder facing you with a screw cap. This is the filter/catch basket - to the right of that is your pump.
Before you screw off the cap, make sure you have lots of paper towels - I had a shop-vac - as I loosened the cap I had the vacuum **** up the water that was coming out - I removed the filter and there was two pencils in there - apparently my son never emptied his pocket. I put the shop vac into the filter chamber and started sucking up anything else that may have been there.
When you put the cap back on, ensure the little notch on top of the cap is facing up, and screw it back on securely. Put the kick board back on - and you're ready to go.
If you continue to have a problem you can clean out the drain tube with a shop-vac - and/or purchase a new pump - but now you see where it is, and how easy it is to change it - you can now save yourself a few hundred dollars by changing it yourself!
IMPORTANT - BEFORE YOU DO THIS UNPLUG THE SYSTEM. This will make sure no injuries, and while you are doing the filter, the computer is getting to reboot itself.
Posted on Dec 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: fagor, washer dryer , model 2F-3611 flashing
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
What does error P03 mean?
Hi,I cant be a hundred percent shore,but I think that it means ( fuel voluem regulater control curcuit low )I hope I am not steering you in the wrong direction,I have a code gide and this is it if im reading it write,all the best.
Sep 14, 2015 | Fagor Washing Machines
Tip
F02 and F09 - valid for Whirlpool Duet front load washer, HE3, HE3T Kenmore,...
Hi.
This tip is valid for valid for Whirlpool Duet front load washer, HE3, HE3T Kenmore,Fagor, amd more washers built by Whirlpool group.
F02 means that there is a drain problem, and F09 is overflow condition. When you get both error , it is usually because of a faulty pressure switch. Better testing the drain system as described below , before replacing the pressure switch..
To start try clearing the error by disconnecting the power cord or tripping the circuit breaker for five minutes. If you can clear the error, then the problem was just temporary.
The drain pump must be accessed as the drain hose is probably clogged. Also drain pump must be tested and eventually replaced.
If you get the error , but there is no water inside, and drain system is working correctly, then test and eventually replace the water level pressure switch, that determines when to start/stop fillng and drain.
If the drain lines are not clogged, the drain pump can be tested by reading ohms at solenoid (contacts on valve), and by energizing the pump directly.
If the pump is fine, then test the pressure switch by jumping its contacts, and advancing cycle to drain to avoid overfilling.
If you get both the codes, the cause is usually the pressure switch
Since one of the codes is overfilling, check if the inlet valve is opening and closing during the cycle, by observing if water starts and stops flowing into the machine, or by reading volts at inlet valve or at electronic control contacts. If the valve stays open or leaks with no volts from timer, then the valve is faulty. If timer is opening the valve while draining, then the timer board is probably faulty.
If water and sensor are OK, then it can be a problem with wiring or control board. Electronic control board causing this error is not common.
Test all other parts first.
You can find parts and diagrams by entering model number here.
Test and repair must be done by a trained person. Call the phone number listed on the user manual if you need to contact a qualified technician.
Regards.
on Mar 25, 2010 | Washing Machines
What does error code f09 mean on a bosch vented dryer,?
F09 error is no heating, you can fix that by opening up the back and pressing the red cutout button which will restore hot air.
Jan 30, 2015 | Bosch Dryers
Fagor fe 948
GOOGLE: fagor fe 948 manuel. lol. its out there to be downloaded.
May 21, 2014 | Washing Machines
Fagor Elegance FE 538 washing machine. A copy of operating manual pl.
i dont know how to use that machine.. FAGOR Elegant FE-538 ..
neet guide or manual ....
Jun 15, 2011 | Washing Machines
Panasonic dmr-ez48v error f09 what is it?
If I have got the right machine than F09 is an electrical fault. If It is a K Deck model (you need to check) then it means: No serial clock linking IC2004, IC7005 and IC7701.
Nov 14, 2009 | Panasonic Televison & Video
Fagor, washer dryer , model 2F-3611 flashing code F07 can you tell me what this is please
Jun 12, 2009 | Washing Machines
Panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
Apr 29, 2009 | Panasonic AG-DV2000 Mini DV VCR
Question: FAGOR FE-1158 ELEGANCE WASH MACHINE
We have a 1 yr old Bosch wash machine w/o problems till now. We have a problem with the centrifuge program-it does not start, although the machine can spin slowly. Is it a motor problem or a problem with the programmer? Thanx for the help in advance!
Oct 16, 2008 | Washing Machines
Sep 09, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
