Star Manufacturing International Star 24" Hot Dog Roller Grill with Duratec Rollers Logo
A
Anonymous Posted on May 16, 2014
How can i get aoster food dehydrator model fpstdh0101 manual ?
Need house & home dehydrator manual
Hello, Vickie -
Do you know the model of your House & Home Food Dehydrator?
Apparently the House & Home Model LD-1010 Food Dehydrator is the same as the Magic Chef Model LD-1010 Food Dehydrator. Also, I have seen information indicating the model LD-1010 is the same as (or very close to) model 469-1. Perhaps yours is a a model LD-1010
I have not yet found a PDF version (electronic, Adobe Acrobat Reader software) of an instruction manual for a House & Home food dehydrator or a Magic Chef food dehydrator, any model.
However, I have found directions (not the full manual) for using a Magic Chef food dehydrator here:
https://www.leaf.tv/articles/instructions-on-using-a-magic-chef-food-dehydrator/
I have found manuals for other similar food dehydrators (PDF documents), which may prove instructive:
http://pdf.lowes.com/operatingguides/1000317095_oper.pdf
and:
https://www.manualslib.com/manual/107232/Mr-Coffee-Fd5.html
Note: I also found a 1997 U.S. Consumer Product Safety Commission for a K-Tel Model LD-1010 food dehydrator:
https://www.cpsc.gov/Recalls/1997/cpsc-k-tel-international-usa-inc-announce-recall-to-replace-food-dehydrators
I have not been able to determine if the K-Tel product was manufactured by the same company which made the House & Home LD-1010 Food Dehydrator or the Magic Chef Model LD-1010 Food Dehydrator. However, I recommend you read the full recall notice and be watchful for any overheating when you use the dehydrator.
Note: If you eventually choose to dispose of the dehydrator, please do not toss it in the trash. Instead, make sure you send it to electronics recycling in your area.
Best wishes.
No manual came in the box? How can I get a manual. I have Lennox computer system!
Free Linux Unix tutorial for beginners Learn Linux commands
https://www.linux.com/learn/tutorials
You will need to find which distro you have and then continue from there. Most are fairly simple and if you get stuck either of the communities on the websites are extremely helpful.
2answers
Oster Fpstdh0101 4tray Electric Food Dehydrator wattage
well, I'm guessing on the tag or label it shows something like this
120V ~ 60 hz 10.5 amps or
120V ~ 60 hz 10.5A or
120V ~ 60hz 11A (some manufactures round up if it falls into the same wire gauge)
120Volts ~ 60hz 1260w or
120Volts ~ 60HZ 1260 watt
120V stands for normal operating voltage
"~" means ac current
60 herzts stands for how many cycles
So if your unit shows only amps, it's really simple to figure out wattage
take the voltage shown, in my example it's 120, then multiply the amps, in my example it's 10.5. So 120 X 10.5 = 1260 watts
W = V * A
and vice versus, if it only show wattage and you needed to know what gauge wire you needed to run a receptical to operate it
AMPERAGE = VOLTS / WATTAGE
I need a manual for oster food dehydrator
go to the yahoo search bar and type in manual for oster food dehydrator if you have a make and model on it it will make the search more accurate ..in most cases you can find an online manual in a PDF file format...hope this helps.
1helpful
2answers
11helpful
2answers
I have a Oster dehydrator Md# FPSTDH0101. When i plug it in and switch on the Off/On switch to the on position the heater and fan do not come on. the switch lights up but it is not running. Help, does...
I have a Oster dehydrator Md# FPSTDH0101. When i plug it in and switch on the Off/On switch to the on position the heater and fan do not come on. the switch lights up but it is not running. Help, does anyone have a wiring schematic?
Top Star Manufacturing International Kitchen Appliances - Others Experts
john h
Are you a Star Manufacturing International Kitchen Appliances - Other Expert? Answer questions, earn points and help others
