Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Water leaking from door of the LG washing machine WD-8015C
  • 2920 Answers
SOURCE: Does anyone know where i
any appliance shop or store carries them
Posted on Oct 12, 2008
praky16
  • 744 Answers
SOURCE: My machine has a small water leak though the door during washing
hi try to Plug off the machine form wall. Open up behind the machine, you will find a thin rubber tube going from the pressure switch near control panel to the pump and exit area..... remove this tube from the top & blow into it, it should be free from any blockage or damage, refit. This tube regulates the water level and switch. If  its found to be damaged, replace it and that will work out for u...
Posted on Feb 10, 2009
SOURCE: hi, have a LG wd-8015c washing machine. had the
called LG and they came out and fixed it for me.
Posted on Sep 09, 2009
sonicboomele
  • 1557 Answers
SOURCE: i have a lg intellowasher 7kg wd-8015c (front
the water pump is sending a signal to the pcb telling it there is a fault clean the filters and wheel on the water pump
let me know how you went
sonic boom electronics
Posted on Dec 28, 2010
  • 106 Answers
SOURCE: Need a user manual for an LG washing machine -
I'm afraid lg has not released that manual on line, however you can call or email lg support and they will mail you a copy.
Posted on Jun 15, 2011
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
LG 7kg wd 8015c
possibly the lid switch when you put the lid down is bad
Nov 09, 2013 | Washing Machines
Lg intellowasher wd-8015c not draining?
Washer won’t drain, I’ve no blockage but water stays in washer and it won’t spin or drain. Can you help me
Aug 01, 2013 | Washing Machines
LG Intellowasher 7kg wd-8015c leak
Most of the time it is the door seal, open the door and check all the way round. check the sump hose and pump, sometimes it can leak from the soap draw hose to the outer tub, but not in your case I think. In most cases this can be fixed easy and is the door seal. to find out if it is coming from the front or the back, just place some news paper on the floor under the machine and take a look to see if it is the front or the back. a door seal is about 15/25 pounds retail
Oct 24, 2012 | Washing Machines
Instruction manual for LG WD 8015C
This link (below) to LG website will get you there, once loaded, click "Support" on the right hand side tab, then on the right side again, you will see "documents" this will get your manual etc, you will however, need to install Adobe Reader if you don't have it already, this is fairly straight forward though. I hope this helps.
http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-front-loader-washing-machine-WD-8015C.jsp
Jun 19, 2012 | LG Washing Machines
LG Intellowasher 7kg wd-8015c is leaking from underneath
the drum.........which you pop ya washing in.......hangs via 2 spring under the machine lid..........if 1 snaps........you will get more noise......and maybe water leaking via the door seal as the drum wont sit level.........
remove lid then look either side for 2 springs.......
if 1 has snapped its an easy fix.......take you about 1/4 of a hour to do.
cheers
Sep 04, 2017 | Washing Machines
Need a user manual for an LG washing machine - WD-8015C
Jun 15, 2011 | LG Washing Machines
I have a LG WD-8015c washing machine. When I put ...
the best idea is to go to the manufactures website and download the user manual and check in the trouble shooting section for possible remedies eric
Jan 01, 2018 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
