Question about Rancilio Silvia Espresso Machine
Steaming won't work
The lights all go on but the machine won't get hot.
I also notice the last time I used it the steaming/froth was not working to its fullest potential.
  • bixkitboy Dec 15, 2007
    Same deal. New machine, used less than a week. Won't get hot. I already tried hitting it with a hammer.
Hit it with a hammer.
Posted on Dec 15, 2007
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
Steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
May 26, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
After frothing the milk it can take ages to reset back to prepare black coffee again. Both lights flash green for up to 15minutes before being ready to make another cup. Does anyone know why?
Hi Jan, This happens because the machine is too hot, due to higher heat being required for the frothing. After frothing, press the button as if you would want to brew a cup,I should blink. At that very same time, turn the steam knob fully open to let some steam out, ,which will lower the inside temperature. This should solve your issue.. Good luck, Claudio
Dec 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Seaco Incanto not frothing milk properly
When was the last time you descaled the machine, and not with vinegar? Scale can accumulate inside the boilers and insulate the water from the heating elements, produce less steam. Descale on a regular basis.
May 12, 2009 | Saeco Magic De Luxe Espresso Machine
Too much water coming out of steam wand
I worked at StarBucks, what we did was put water into a contaner and steam the water, a lot of the time why the steamer doesn'..t work as well is because it is clogged. Another way to do it is to just run your steamer, also go to a coffee store and buy expresso machine cleaner. It could just need a good cleaning.
Apr 16, 2009 | Breville ESP8XL Espresso Machine
Brand new Incanto Classic bought online, not working after 1 month
First, machine should be under warrantee- check with
Sounds also like you have blockage in the steam wand- every time you froth milk, you should let some water come out- to prevent clogging. Try first inserting a pin into steam want ( machine turned off) to see if that alleviates the problem. Also contact
Saeco USA 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at :
Mar 17, 2008 | Saeco Incanto Classic Espresso Machine
Starbucks Athena
I have had this machine for four years now, and it is FAB!!! it does have an extra step to it- after you put in coffee and add water to the reservoir, you DO need to prime the pump. So here's what you have to do:
-Fill the reservoir with MORE water then you think you will need, fill the coffee filter with the standard amount of finely ground bean.
-Turn the machine to "on," making sure the "steam" switch and valve (knob) are off.
-Wait till the green "ready" light comes on, then put an empty cup under the steam wand and turn the valve on (the steam switch is still in the off position). Hot water will come out of the steam wand, allow it to flow until the "ready" light blinks off. Discard this.
-close the steam valve, stopping the flow of water.
-turn the "steam" switch into the on position, wait for ready light to come on again.
-put your milk container under the steam wand and froth to your heart's content (this machine makes GREAT frothed milk and you should use a large enough milk container to allow for that! *smile*)
-when you have finished with the frothing, close the valve and flick the "steam" switch back into the off position. You are now ready to make your espresso.
-push either of the two buttons, ie one or two cups, and the espresso will start to flow. There is a way to set the length of time for each of the two buttons, but I have had mine set perfectly for so long i don't know how to do it any more. Sorry!
This has been the best machine I've ever used, and has lasted me for years. I heartily recommend it!
Jan 02, 2008 | Estro Barista Athena
Rancilio Silvia Espresso Machine Logo
83 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
