Question about Thetford Norcold RV Cooler/Freezer
Why does my Norcold fridge on Jayco 2014 come on but does not get cold?
Nor cold Fridge has power but does not get cold.
    Top Expert:
  • Thetford Master
  • 8,686 Answers
If chimney cold check heater element and LP for flame if chimney hot unplug thermistor from control board let run if gets cold replace if not either bad board or cooling unit
Posted on Jan 11, 2018
  • 171 Answers
SOURCE: reset Norcold 'N61 Series' Fridge after lockout
Hi Lynn1965,
I'm Harvey the Master Plumber.
Yor problem is: Please help! Your brother phoned you on his cell from up north. He's supposed to go hunting tomorrow, and is having problems with his fridge. The nearest dealer is 5 hours away, and he's very upset.
The fridge went into lockout mode after accidentally resetting twice. Now, the lights flash, and fridge doesn't work.
Please advise how he can fix this problem himself. You both would greatly appreciate it!!
First, unplug the unit for 10 minutes. That should reset it. If not, ask if he can here the compressor motor. If not, then he has a compressor or electrical failure inside. If yes then look to a bad thermostat.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
  • 159 Answers
SOURCE: my norcold n61 freezer is cooling but the fridge
low gas in the system
Posted on May 15, 2009
SOURCE: RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
  • 332 Answers
SOURCE: My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Posted on Mar 15, 2010
SOURCE: norcold 682 is 0 in freezer and 50 in fridge
How about checking the R12 charge? Or you can run the fridge on propane and see if it gets colder. Which might mean your compressor is going bad.
Posted on Apr 15, 2010
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Elite troubleshooting
fan is what circulates the cold air from he freezer to the fridge.. check for bad fan
Aug 27, 2014 | Refrigerators
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
PDS22SCRRSS fridge not getting cold
could be a fault in the power chord or a fault in the fridge itself, i suggest you get a new one.
Jun 29, 2014 | GE PDS22SCRRSS Bottom Freezer Refrigerator
Where can i downoad jayco user manual
Contact the manufacturer of the coach for their owner's manual. However, each appliance will have a separate owner's manual form its perspective manufacturer, i.e., Water Heater = Suburban, A/C = Dometic, Refrigerator = Norcold, etc.. There will not be a diagram of electrical or plumbing as a majority of the RV manufacturers do not publish that information.
Jun 02, 2014 | Jayco 2014 Greyhawk 31SS
Fridge will not work on AC mode. AC is present into fridge.
There should be a code appearing on the display. If you are not getting any 12V to the Fridge your fridge will not function. You may also want to check for any blown fuses inside the electronic board assembly. ">
Aug 30, 2013 | Norcold Inc Norcold 1200LRIM Refrigerator
Miele Fridge Freezer not getting cold
Power off and remove all fluff under the fridge.
Compressor can be hot but not too hot. Are the settings ok for desired level cold. Is the fridge too heavily loaded? Try now.
Aug 07, 2013 | Miele Microwave Ovens
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 10, 2012 | Thetford Norcold RV Cooler/Freezer
Thetford Norcold RV Cooler/Freezer Logo
141 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
