Tcl air conditioner wont heat
My tcl air conditioner model TAC-24CHS, only blows cool air when on heat
2 Suggested Answers
flatech
  • 111 Answers
SOURCE: TCL model tac 24chs/k air conditioner is leaking from the
You will want to remove the panel in front of the air handler, usually a few 5/16 screws.
Once open then with a flashlight look down inside where the water collects in the condensate drain pan.
Verify that the pan is not full of water or algae build up.
If it is, then attach a wet vac to your drain outside and while it is pulling on the drain line spray some water inside till it is fully clean.
If it is not full of water then check the pvc pipes that are attached to the drain pan, they may have came loose and may need to be teflon taped and reconnected to the pan. Also verify there are no cracks in the pan.
Lastly inspect the bottom of the evaporator coil (Not the top) pull out the filter and make sure the coil is clean or water could drip down past the pan into your dwelling. Make sure as well that the insulation on your panel that covers the unit is intact and not worn away.
Good Luck!
Posted on Nov 14, 2009
What does Ft mean on a TCL portable air conditioner
FI - Failure1
This message could appear if the water filter is particularly clogged. See section: "Re-placing the limescale filter".
If the filter has been replaced recently, contact your local authorised service centre.
http://airmaster.net/delonghi-portable-air-conditioner-troubleshooting/
http://acerrorcode.com/tcl-air-conditioner-error-codes.html
Jan 06, 2017 | Heating & Cooling
How do I refill water in a portable air conditioner. TCL TAC-09CP/C
If it's an air conditioner it probably needs freon and not water
Dec 19, 2015 | Miscellaneous
Unit blows cool air while in heat mode
model number? Heat pumps tend to blow cooler air than a space heater unless in money-gobbling mode.
Mar 28, 2014 | LG Heating & Cooling
Air conditioner TCL TAC-12CHS/G not cooling
you could have ither an electronic or lectrical problem, your electronic board in the inside unit or a bad capacitor for example not letting the compressor to run. call a service man or some thng
Jan 26, 2014 | Heating & Cooling
Kenmore window air conditioner model 580. Blows air but nott cool air. wont cool the room.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 02, 2011 | Kenmore 76129 Air Conditioner
How to put my tcl air conditioner on heat
Make sure the unit is a reverse cycle first... It may be a cooling only modle. If its a heat ( reverse cycle ) unit, there will be a symbol which looks like a star, the machine will generally sit with the outside unit running for up to 5 mins before the indoor unit starts. ( Preheat mode) If the unit doesnt start, possibly a failed air or pipe sensor. If it starts but wont heat, possibly a faulty reversing valve coil. Cheers.
Jun 05, 2011 | Heating & Cooling
TCL air conditioner wiring
John what is the problem ? My 18CHS gave me problems but are now fixed. Maybe I can help
Dec 18, 2009 | Heating & Cooling
I have a TCL 2.5hp split system air conditioner (model TAC24chs/g) that wont cool or heat...only blows room temp air. The outside fan is working and i have cleaned the filters.No water is dripping from...
I will star checking freon pressure but you going to call an HVAC company to do that. Please turn it off or you will damage the compressor, if is not already.
Dec 06, 2009 | Heating & Cooling
Good Luck!
Nov 14, 2009 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
