Question about LG Televison & Video
Lg 24ln4510 has stopped responding to buttons on tv and the remote
jerryg50
  • 1667 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
  • 9 Answers
SOURCE: tv wont respond to remote
is it the factory remote? if it is check to see if something is blocking the sensor on the tv, clean the sensors, if it is a universal remote alot of new tvs have codes that even some of the new universal remotes dont support. if thats the case you will just have to make do.
Posted on Nov 02, 2009
walesarumi
  • 6993 Answers
SOURCE: The TV will not respond to the remote and
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
You need to do some diagnosis to confirm the source of the problem.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Posted on Nov 28, 2011
  • 302 Answers
SOURCE: LG 47lg50 white screen no buttons responding
A white screen with nothing else leads me to believe you have a problem with a t-con board or a signal board on that TV.
you can get parts for this tv at www.interliquidparts.com
Posted on Feb 25, 2012
  • 3 Answers
SOURCE: Hello I'm finally back again I got a customers LG tv Model #37lg30 it does not respond to the remote the buttons on then side alow us to operate the tv I tried the remote on another
Check on the back of the TV to see if you have a "remote in" port. It will look the same as a 3.5mm headphone jack. Unplug the TV and plug a pair of headphone into the port and then remove it. Do this several times to breakup any debris that may have gotten into it or corrosion that may have occurred in the port. If something is in the port it will disable the standard remote sensor on the TV.
Posted on Mar 25, 2012
Channel 4 stopped working. No other problems.
Hi Harold
TV may have simply lost the ch4 frequency from memory.
My TV did this 2 months ago and it blew me away as all other stations were fine.
Put it down to Cosmic Rays!
Simply run the Automatic Station Finder from the main settings menu. This will reload all receivable stations back into it's internal memory storage again.
Other than that.... is ch4 still on air.
Good Luck
Jan 03, 2016 | LG 24LN4510 24" 720p LED-LCD TV - 16:9 -...
What can cause an LG 47LN5700-UH TV not to turn on or respond to the panel buttons or remote control?
TV in totally unresponsive in many if not all areas. Only thing they all have in common is the set's power supply. They are big culprits.
Check the board for burnt rsisitors, diodes, bulging capacitors.
Aug 21, 2015 | LG Televison & Video
Feb 24, 2012 | LG 47LG50 47 in. LCD HDTV
None of Tv controls on side of tv will not work and remote will not work
MAY HAVE A STUCK BUTTON SUGGEST PRESSING EACH BUTTON HARD AND SEE IF ANYTHING CHANGES. THE MAIN MICRO PROCESSOR IN THE TV WILL RESPOND TO BUTTON COMMANDS BEFORE ALL ELSE SO IF THERE IS A STUCK BUTTON NO OTHER BUTTONS WILL WORK AND IT WILL NOT RESPOND TO THE REMOTE.
Dec 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Need codes for LG tv from rca remote thank u.
Hi! You can try using these steps for you to program your RCA remote control to your LG TV.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the device does not respond, repeat steps 1-6.
I hope this works for you.
Jul 13, 2010 | RCA Universal Remote Control
My remote Stopped working with my TV but still works with DVD player. I have a new universal remote and it will not work as well, what part Do I need to replace?
You may want to try a “Hard Rest” by unplugging the power from the TV.
While the TV is without power, one at a time, push on each of the buttons on the TV & listen to hear them click (there may be a button stuck down).
After at least a few minutes have passed, plug the TV back in. Sometimes the TV may power on by itself and other times it will may not. If the TV did not power on by itself, push the button on the TV to power on the unit.
After the unit has power on wait about 30 seconds. Now point a known working remote at the TV and see if it is working correctly. You could test your LG remote on another LG TV at home, a neighbor’s house, and or at a store.
If the TV does respond by using the buttons on the TV but not with remote control, the problem could be with the following.
Remote Eye board and or the Main board.
I hope my information has helped you.
Good Luck.
May 28, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
TV not responding to Remote
needs fireware update call LG
Sep 22, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
29 people viewed this question
Computer Repairing
Computer Repairing
