Question about Sport & Outdoor - Others
Difference between eight sided to a four sided mortar boards used for graduations?
The mixture of sand and cement for laying bricks
mortar proportions are always expressed as a proportion of cement to lime to sand and always in that order
common mortar made from portland cement has one part cement to one part lime and 6 parts sand ===1:1:6
Cement bags have the mix written on the side for mortar mix or concrete mix or you can get mortar mix cement which already has the lime added
Oct 22, 2016 | Washing Machines
Tip
Tips to Use Computer Network Cabling
Problems in computer network due to computer network cabling can be stressful for someone. follow the simple tips mentioned below to keep away from issues caused by network cables:
They come with eight wiring standards which are T568a and T568b. to keep away from any trouble it's recommended that you ought to not merge the eight wiring standards on a same network.
in case you are fixing network cabling in a brand spanking new place, it's suggested that you ought to go in for patch panels to forestall any computer network problems.
in case you need your cables to give an optimal result make positive you buy the right plugs for them.
Make positive the cables you use are not over eight hundred sixty four feet long and ought to be devoid of any joints.
Network cables ought to not be placed along the electrical cabling and also avoid suspension of network cables on ceiling.
To prevent any network issue make positive that no network cable is crooked or even turned. And also stay away from metal pins for securing cables.
A network cable consists of four crooked wires which come in different hues of brown, orange, blue and green. To steer clear of any network issue make positive that not over a quarter inch of the cable is untwisted at both the ends.
As mentioned above that a cable has four wires. usually only eight are used but still it's essential you keep all the pairs wired to uphold network requirement.
While doing network cabling for your network always use the highest quality tools. receive a lovely quality crimping gizmo for the same. basically steer clear of pliers.
In areas where radio frequency is on the higher side, try and use shielded crooked pair or STP network cable in lieu of unshielded crooked pair or UTP network cables to avert meddling.
on Jan 13, 2011 | Computers & Internet
Is post graduate diploma in business management and MBA same?
No, the former is a lessor than the latter.
A diploma is less than a degree. You would take a diploma and if successful take the MBA at a later date.
Apr 19, 2016 | Computers & Internet
When were mortar and pestle invented?
Mortar and pestle seem to have been used since anchient times to grind seeds and plants. There are sources of its use both in the Egyptian Ebers Papyrus (1550 BCE) and the Bible.
Different variations of mortar and pestle can be found in almost every culture, all over the world.
Sep 12, 2013 | Home
Assay about graduation.... give me a example of assay of graduation
Prior graduation arrangements include student's responsibilities. First, provide the details to registrar department to compile academic resources requisite. For example, informing the school registrar about intentions makes certification documentation either in pursuit of career or reacquiring advance education on same campus or elsewhere. Prior graduation arrangement from school requesting student participation would be attainable. For example, among mentionable are request participation to ceremony of graduation. Details about the process are attainable from registrars also from academic counselors from students departments. Third, participation at the entire events is organized by students department also from the school in recognition of completion of academic processes. An elaborate description of the event includes graduates presence at gathering comprising school staff among which student's department officials. The event commences with schools authority speeches among which department leaders reference participation. Entire process is finalized with the presentation of certifications of accomplishment to graduating students. Also presented are awards of achievement from requisite entities. At completion of graduation ceremony, students are pronouncing graduates to professional endeavors.
Feb 28, 2011 | Aspen Graduations Antique-Finish Photo...
Replaced caps. More problems. Gateway, why....?
It may be a problem with other capacitors on that same board (other than the group of eight). Also, there are four MOSFETs surrounding the group of two capacitors closer to the middle of the board. I'm ordering parts now for mine. Two of the eight tall/blue capacitors in a bunch have tops that are bulging (but I'll replace all eight since they're cheap). There's a pair of two in the middle of the same board on mine with bulging tops and there are four transistors in that same area that look like they got too hot. Most people seem to be getting away with only replacing the bulged capacitors but here is my total part list from digikey.com:
785-1106-1-ND quantity 2 (the D405-marked transistors) 785-1114-1-ND quantity 2 (the D408-marked transistors) P12389-ND quantity 8 (the 470uF capacitors) P12383-ND quantity 2 (the 220uF capacitors)
The total part list is about $7.50 with another $2.50 or less shipping. It's a pain to take apart, given the small connectors inside. The fix assumes you have soldering skills.
Go with these from digikey versus Radio Shack. They're rated for 220 degrees fahrenheit versus only 85 degrees and they're about a third less cost.
Mar 14, 2010 | Gateway FPD2185W 21 in. LCD Television
Need to know where the #3 cylinder is located
#1 is closest to you on right side then three in middle on right side and then five, then seven on right side.
On left side is two, four, six, and then eight. Eight is far back left corner
Nov 28, 2009 | 2004 Cadillac CTS
Help me solve
1. Four Hundred Seventy-Eight Ten Thousandths
2. One Thousand Four Hundred Thirty Five Ten Thousandths.
3. Three Thousand Two Hundred Five Ten Thousandths.
4. Four thousand Seven Hundred Eighty Four Ten Thousandths.
5. Four Hundred Ninety Seven Ten Thousandths.
OR
1. Zero point zero four seven eight.
2. Zero point one four three five
3. Zero point three two zero five
4. Zero point four seven eight four
5. Zero point zero four nine seven
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Audio Players & Recorders
Sport & Outdoor - Others Logo
230 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
