Question about Xerox Office Equipment & Supplies
Sharp mx2614 Toner density sensor trouble
I am getting an error F2-43 Toner density sensor trouble (YELLOW) Check Toner and Crop - Change toner if required. The toner is new and when I put the old one back in the same error
  • 77 Answers
SOURCE: B8300 toner error
From Oki's site: Symptom: The toner counter did not clear after installing a new toner cartridge. Cause: The printer was not powered off when the new toner cartridge was installed, Therefore the counter did not cleared. Resolution: 1. Enter the PCU Diagnostic Mode, By turning off the printer and holding down the MENU and OK buttons on power up. (Release the buttons once you're in the PCU DIAG MODE) 2. Press the MENU button 14 times until the operator panel reads " Counter Display " 3. Press the MENU button and the BACK/C button at the same time, This will put the printer into the Feed Counter Clear Mode (Release the buttons once you're in the Feed Counter Clear Mode) 4. Press the up arrow 5 times until the operator reads " Toner Counter Clear " 5. Press the OK button, The operator panel will now display " Toner no " 6. Press the up arrow once and the operator panel will display " Toner yes". Now press the OK button and the green data light will flash to indicate that the clear process is complete 7. To exit the PCU Diagnostic Mode, By turn the printer off and then back on this will allow you to exit the PCU Diagnostic Mode Hope that helps. If it does not please let me know Ed
Posted on Jun 13, 2007
Soulvisitor
  • 1113 Answers
SOURCE: toner sensor problems
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
Posted on Nov 13, 2007
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
  • 3 Answers
SOURCE: put a new toner in
I have indicated the solution in another post for C3400n. Basically on the right hand side of the drum there is a small rectangular opening of 0.5" x 0.25", ensure that the shutter in that opening stays open to allow the RFID chip to be read by the printer. The shutter may get jarred shut while changing the toner cartridge.
Posted on Jan 26, 2009
SOURCE: I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
Posted on Jun 17, 2009
How do I clear this error massage (system error (f2-64) refer to user guide) from sharp mx-b210d
Remedy
Replace the toner motor. Replace the toner density sensor. Connector and harness check. Replace the PCU PWB. Replace the toner cartridge. Replace the developing unit. Check the toner transport pipe section.
Dec 12, 2017 | Sharp Office Equipment & Supplies
Konica minolta bizhub C253 is showing me trouble code C- 2556. What should I do to pix this problem
Konica-Minolta bizhub C253 Trouble Error Codes List page 4
Code C2556
Abnormally high toner density detected yellow TCR sensor
• TC ratio in the developing machine, which is determined by toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively. • When the connector of the TCR sensor is disconnected.
Solution:
1 Reinstall imaging unit. 2 Reinstall toner cartridge. 3 M3, M4 operation check (At this time, IU must be non-installation.). 4 Change imaging unit. 5 Change PRCB
Extract from:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C253&page=4
Nov 14, 2015 | Konica Minolta Office Equipment & Supplies
Sharp mx-2700n code f2-65
Toner motor trouble. Toner density sensor trouble. Connector/harness trouble. PCU PWB trouble. Toner cartridge trouble. Developing unit trouble. Toner transport pipe section trouble
Jul 07, 2014 | Canon ImageRUNNER 3570 Copier/Printer
Error code f2-4
toner density trouble,
check developer mag sensor located at bottom of DV unit
check toner motor ,
check DV-unit gear assembly
Jun 15, 2014 | Sharp AR-207 Copier
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
Sharp MX-M450N getting F2-00 error and the AR455NT toner not working.. i know it means sensor open it is a new machine and already getting error... cant find nothing in manual on how to repair this issue
F2 00 Content Toner control sensor open/sensor
trouble
Detail Toner control sensor output open
Cause Connector harness trouble
Connector disconnection
Sensor trouble
Check and
remedy
Check connection of the toner control
sensor.
Check connection of connector and
harness to the main PWB.
Check for disconnection of harness.
Replace the sensor.
This is right from the service manual...one thing you can try.
1)copier must be up to ready state.
2)press #,*,clear,*(that will enter you into a simulation mode)
3)press 14, execute,yes.
4)or 14, print button.
5)press CA (clear all) button.
that should reset it to a working state without causing any damage to the copier.
Jul 29, 2010 | Sharp AR-BC260 Color Copier
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
My sharp ar5316e show f2 04 solve this
clear the memory of the machine, change the destination of the toner or fixe in a new toner crum or also known as toner sensor
Jul 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
Ar405 error code f2-31. how do i solve this problem I have the same issue, anyone have a "fix" it cam up right after we changed the toner Same problem, code F2-31 popped up after adding toner. I looked up...
Content Process control trouble (OPC drum
surface reflection rate abnormality)
Detail Usually the sensor gain is adjusted so
that the output is a certain value, by
reading the drum base surface with the
image density sensor before starting
process control.
However, a certain output is not obtained
by adjusting the sensor gain.
Cause Image density sensor defective
Check Check process control sensor output with
SIM44-2. (Do not adjust)
and
remedy If the result is far different from the
specified value, it suggests the sensor is
defective. Check the sensor and harness.
If the deviation is relatively small, check
the sensor and drum surface for
contamination.
Jun 02, 2009 | Sharp AR-405 Printer
304 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
