Question about Soleus Dehumidifiers
Why can not remove filter from Soleus GL-DEH-70F-2?
Why is my soleusair dehumidifier model GL-DEH-50 say F2
Pipe Temperature Sensor Malfunction.
1.
Unplug the dehumidifier.
2.
Check the surrounding area
for possible reasons for sud-
den temperature changes.
3.
Wait 2 hours before plugging
the dehumidifier back in for
normal operation.
4.
If the "Error" is still indicated,
please contact customer
service. Call 1-888-876-538
Soleus Air SG DEH 70EIP 6 Operating Instructions Manual Error Codes...
Jul 31, 2017 | Dehumidifiers
I have Soleus Air, Powered by Gree.Modei# sg-deh-30m-1 .S/N 54930000806. Is on a recall? dehumidifier
call manufacturer or store and ask using make ,model whwn and where bought
Jul 27, 2017 | Soleus Dehumidifiers
Why is water going to the bucket instead of getting pumped out the hose? Does this mean the pump has quick working?
It is possible that the drain hose is not properly positioned. It is very fussy about that. Here is a link to the manual on PDF. See pages 8 thru 12.
http://www.soleusair.com/Manuals/2013%20Manuals/Dehumidifier/SG-DEH-70EIP-6%20Manual%2012-05-12.pdf
Oct 23, 2015 | Soleus Dehumidifiers
Dehumidifier is not draining out of the hose.
The hose is most likely clogged. Try blowing into the end of the tube to loosen up the dirt in the water tank. You can use compressed air if you have it but plan on water spilling out of the back to be safe.
Jun 03, 2015 | Soleus Air DP2-70-03 aka SG-DEH-70-2...
Do you have a manual written in English for the AC listed.
This is just a world wide free chat room
There is no one at FixYa answering anything
Just people at home like Facebook
So call the company or use the internet to
find a manual online
Jun 02, 2014 | Soleus 8000 BTU Evaporative Portable Air...
There is a part inside the water bucket with a wheel. Where does this attach to the unit?
I have a sg-deh-30-2 model and the unit seems to be doing everything right,the filter is clean the motor is running and room temp is 75 but the machine is not dehumidifying the bucket is dry
Jun 17, 2012 | Soleus DP2-70-03 70 Pint Flat Panel...
I have a Soleus Air Dehumidifier, Model SG-DEH-70-1A, I cannot get it to drain through the hose rather than into the bucket. The instructions say to simply hook the hose up, which I have done, but it...
Several things play a role in the problem you're having.
1. The length of the hose. Shouldn't exceed 5 feet.
2. Is the hose sloping downward from the unit with out any kinks or twists. Most dehumidifiers rely
entirely on gravity to drain the water by hose. It will not drain up and over anything.
3. Is/was there a knockout plug on the dehumidifiers hose connection, that was not removed?
4. Is there a clog in the hose? If so, the water will divert to the bucket.
5. The unit's hose connection or interior tubing is clogged. To solve this problem do the following.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connector hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Then monitor the hose for water flow.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 27, 2011 | Soleus Dehumidifiers
How do I remove the cleanable filter? I cannot find the manual for my Soleus dehumidifier.
The filter is located on the right aside of the unit, behind the louvers on the front. To remove it, look for the finger hole on the side and pull the filter out. You can either vacuum the filter or wash it in tap water. If washed, be sure it's thoroughly dry, before reinserting it into the unit. CAUTION: Never remove the filter with the unit ON.
Below is a link to the Owners Manual, that you may download and print for future reference.
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-Appliance-Site/Sites-CompactAppliance_Primary/default/v1305703058935/pdf/ownersmanuals/edgestar/DEP400EW_manual.pdf
Hope this helped you solve the problem. Please let me know. Thanks.
May 24, 2011 | Soleus 30-Pint Dehumidifier
Dehumidifiers Logo
49 people viewed this question
Top Soleus Dehumidifiers Experts
J.D. Browning
J.D. Browning
jeff5may32
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
