Question about Sunbeam Coffee Makers & Espresso Machines
My milk steamer is not working, i just bought it brand new. Can anyone assist?
Cafe Series EM7000
dutchman05
  • 487 Answers
SOURCE: Milk Steamer takes too long
means the temp is not high enough or pressure not high enough
1) descale the machine real good
2) if not workin your thermostat or brewer can be broken.
Let me know if you still have problems after this descaling
And by the way poke a needle through the steam spout as that can be clogged too..
have fun
Posted on May 05, 2008
  • 833 Answers
SOURCE: Steamer and milk frother not working
This sounds like one of several problems:
1. Does any indicator light come on? If there is one and it doesn't you either have a bad thermostat (size of a dime/1/4 inch thick) black item with two wires attached to the chamber or a bad heater. Check both with an ohm meter...Resistance of any kind across the terminals means okay.
2. Could be the switch. Same kind of test.
3. If you've got a steam leak, deal with that...new cap or valve.
Make sure all wire fasters are clean and bright. If screwed down, make sure they are tight. Cycle each connector off and on to clean them.
Remember: always work on your unit with it unplugged. You may need torx screwdrivers to open this unit. Any hardware store will have sets of these items.
Posted on Jun 16, 2008
  • 4 Answers
SOURCE: New Rancilio Silva - steamed milk not perfect
Make sure the milk (doesn't matter the fat content) is COLD. Then USE EXTRA MILK...(more than you need) that way it stays colder during the steaming, and it will froth instead of break. If it heats up too fast with too little milk... it will start to bubble and remain watery instead of producing froth. I use almost a full cup of cold vitamin D milk.... then I keep the steam head just below the surface..... Do not put the steam head at the bottom. This way some air is pulled into the steam and helps start the frothing process. I continue bringing the cup of milk lower and lower as the foam gets higher and higher, so the steam head continues to be just 1/4 inch below the surface. You will have super creamy foam (not bubbly foam). It takes a while to get perfect, but its worth it. Don't worry about expunging the condensed water at the start ... that really doesn't make a difference. Hope this helps!
Posted on Jul 29, 2010
lesmilltoits
SOURCE: Nespresso Aeroccino 3 does not heat and froth
I got mine today exact same thing happens... only blue does not warm AT ALL
Posted on Nov 30, 2012
fran_trudy
SOURCE: Milk frother /steamer not working
you have got it wrong its avax steam hard floor cleaner
trigerbroke you soposed to fix it you sent it back to currys
it still dose not work could we have our money back
Posted on Feb 03, 2014
I have an Emerson EM7120 cordless phone and want to add a handset EM7000. How do I do it?
GOOGLE! GOOGLE! GOOGLE!
emerson EM7000 manual
Google
First thing on the list!
look for Registering your handset.
Aug 04, 2016 | Emerson Lands Phones
No milk or frothy milk being dispensed
Link to manual
Milk may not be frothed optimally. In these cases simply turn the flow regulator as shown in the figure.
Turn the regulator 2-3 times to perform a quick maintenance.
Note: If the assembled regulator is missing, replace it with the other 3 regulators provided.
There is a pump
English version of manual pages 101 to 149
Dec 21, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Sunbeam cafe series starts up as soon as it is plugged in
If you mean pumping, it could be it thinks it is empty OR you have blown the main board
Sep 06, 2014 | Sunbeam Cafe EM6910
Cafe barista not frothing
the frother gradually gets milk buildup and loses suction- an air blast through the milk tube and up the spout (can get an aerosol at hardware store) will help as well as the cleaning cycle. Also I used a q tip to the top of the spout several times but just had the q tip top come off and may have blocked it completely
May 05, 2014 | Sunbeam Mr. Coffee Cafe Barista Espresso...
Why don't the three lights come on after a warm up period?
Is it actually getting warm/hot? The thermal fuses on the Cafe Series often blow after a few years, so the machine doesn't go into ready state.
It's a replaceable part bolted to the steam thermoblock. Costs about $9.
Apr 25, 2014 | Sunbeam Cafe EM6910
Wet steam, poor pressure
Have you tried cleaning the steam wand nozzle with a paperclip (or the pin tool mounted in the back door of the unit?
Milk deposits can make their way inside the nozzle and block it, describing the symptoms you're getting.
Apr 12, 2014 | Sunbeam Cafe EM6910
Where can i get the ge cafe microwave handle cover?
You can find links to helpful exploded view diagrams and order parts here.
Dec 27, 2012 | GE Cafe Series CVM2072SMSS 2.0 cu. ft....
Ge range adjustable feet
you have to get them from GE
Sep 20, 2012 | GE Cafe C2S980S Kitchen Range
Steam wand doesn't work on sunbeam cafe series coffee machine
Sep 11, 2012 | Sunbeam Cafe EM6910
Coffee Makers & Espresso Machines Logo
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
