Question about Whirlpool GU2400XTP Built-in Dishwasher
What is the black wire? - Whirlpool GU2400XTP Built-in Dishwasher
    Problem Solver:
  • 16 Answers
My need more info but normally that would be a hot wire.
Maybe post an image
Posted on Jun 03, 2014
How do I wire in the fuel pump on a 1992 F-150
It appears from a wiring diagram the yellow/white and the pink/black go to the fuel sending unit. Match the black wires together.
You can see a wiring diagram here:
Oct 15, 2014 | Ford F-150 Cars & Trucks
Trying to connect a Tork A530 MW timer to a spa tub pump
  1. The white wire (neutral) in your feed cable from the electric panel should be connected to the white (neutral) wire going to the pump.
  2. This switch is wired in 'series' in the hot (black wire) leg. That means one black timer wire connects to the black wire in the feed cable from your electric panel and the other black timer wire connects to the black wire that goes out to the pump.
  3. I the diagram the switch is your timer and the light bulb is the pump. The switch is in series with the pump.
Nov 13, 2013 | Tork Spring Wound Interval Timer
What are the color code of the wires to switch terminals
Almost!
the black screw is the "common" so the hot wire or the colored wire (usually black or red) bringing power in goes on to the black screw and all white wires (neutral) get connected together. you need to verify which wire has constant power when all wires are disconnected and separated first.
*White wires all connected together separate of the switch
green screw = ground or bare wire
black screw = hot wire/ wire with constant power
silver screws = (switched terminals) black or colored wire from each device being powered (eg. light) per screw
Dec 22, 2012 | Leviton 003-1755-W Three Rocker Switches
Wiring a master flow PT6 thermostat to attic fan
I had a roofer install Master Flow PRO 3 and he did the initial wiring incorrectly. The black wire pairs were incorrectly connected and caused the fan to run 24-hours. I switched the black wires pairings and the fan shuts off if less than 100-degrees (the setting I chose) and comes on if more than 100-degrees. You may want to be sure that the black wire from the power source is connected to the black wire for the thermostat (black wire nearest the thermostat setting switch and closest to the power source wire). The black wire from the fan motor should be connected to the black wire closest to the fan motor's wire.
Aug 01, 2012 | Cars & Trucks
Utilitech Wall Timer #0192773 does not switch landscape lights on? Replaced Intermatic that had 3 wires. Black to Black, blue to black and red was capped. Utilitech came with 4 wires - black, white,...
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Sep 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I am trying to install utilitech 7 day in-wall timer. Their are 3 switches in box controlling different fixtures. The old switch had black connected and a black looped to the next switch. How do I connect...
1) Wires in box:
Black looped to to next switch is Black hot wire
Other Black goes to fixture
2) Connect timer wires
Black timer wire goes to Black hot
Red (or Blue) timer wire goes to fixture
White wire connects to white neutral wires (usually connected together with wire nut and pushed to back of box)
Green goes to bare ground wire
Sep 04, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I lost my Leviton 6230M 30 mins timer installation sheet.
Switch has 2 black wires. One black is hot wire. One black is wire going to fan. Turn off power. Remove wires from switch and separate. Turn power back on. Using ordinary tester, test each black wire to bare copper ground wire. Only one of the black wires will test hot. The other black wire goes to fan.
Timer black wire connects to black hot
Timer blue wire connects to black wire going to fan
Timer white wire connects to white neutral (in absence of white neutral, connect Timer white wire to bare ground)
Timer green connects to bare ground wire
May 24, 2010 | Leviton 1000W / 20A 1HP-120V - 6230M-I -...
Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
May 24, 2010 | Westinghouse Electric Westinghouse...
Wiring a ceiling fan with light fixture. there is a black and white stripe wire, one black wire, one white wire and ground wire. Coming out of the ceiling is two black and one white. one copper. please...
The black and black with white stripe are for the light and fan respectfully. The white wire is your neutral. That leaves the ground to your copper ground wire. If you have two seperate switches to operate the fan and light then the two black and black with white will tie in to seperate black supply wires. If only one switch then they will tie in together to the black supply wire.
Sep 20, 2009 | Hunter 52" Ceiling Fan With Light And...
Bought a hunter remote and can't figure out what wires to connect
The remote red wire should go to the black wire that goes to the light. The remote black wire should go to the black or black with white stripe wire to the fan. The white wire should go to both white wires from the light and fan.
The power in (black and white) should be connected to your power source black and white. Bare copper wire to ground on fixture
Jun 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Whirlpool GU2400XTP Built-in Dishwasher Logo
22 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
