Question about Humidifiers
How to adjust height of pj-lr-48c ocean mist led light fountain
My humidifier is not working first times worked great
The manufacturer states you can use tap water in these devices, but then goes on the disclaim that if you have water with minerals or hard water then white "dust" deposits can occur. Theses deposits are supposed to be noted and if seem, you are to change to filtered or distilled water or purchase one of their filter cartridges. These devices use very tiny holes to produce the mist you get out of them. It takes almost nothing to clog them. You should always use distilled water in these devices to prevent clogging. They also require very regular cleaning to stay clean and thus prevent them from becoming mold fountains. White vinegar and water should be used for cleaning. Avoid detergents as they can gum up the inner workings of the unit.
Sep 08, 2016 | Crane Ultrasonic Cool Mist Teardrop...
Heater Element for Hunter Niteglo Humidifier is not working
Heating elements are pretty reliable. They usually have a thermal fuse or thermostat that will open before ruining the element. If your handy with a multimeter, you can check the continuity of the parts and the element itself.
Mar 04, 2014 | Hunter 35216 Warm Mist Humidifier w/ 1.2...
I do daycare a parent brought me the nebuilzers/breathing machine it sounds like is on but I see no mist or vapor I disesemble to see if i feel air and i do but i see no vapor mother tells me it just...
Is there distilled water or liquid medication in the container? If not, all that will come out is air. There should be an adjustment valve on the hand-held part of the nebulizer, that adjusts the liquid flow and turns it into a mist.
Apr 01, 2011 | Humidifiers
No mist, but i can see a water droplet fountain on the surface
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
Mar 12, 2009 | Sunbeam Ultrasonic Humidifier
No mist!
unfortunately on a cool mist unit the mist shouldn't show up. on most units that's what it does. the warm mist units show the mist.. the best way to tell is if you put your hand over the spout that the mist is suppose to come out of for about 2 minutes and you pull it away and it feel clammy then it's working. if your hand is still dry please let me know and i'll see what else i can do for you.
Feb 26, 2009 | Holmes Products HM500-UC 1 Gallon...
Sunbeam Ultrasonic Humidifier 696-12
tentative on the Solution icon ...
I picked this up a couple days ago at the Salvation Army, 3 bucks. I also had way too much damp coming out, saturating anything near.
I read through the comments, and one folk said they uncovered the spaz unit and tightened the screw they found there, to no avail. They asked if they should reopen and loosened the screw ...
Which I did. Took me a while, and maybe those who aren't used to investigating the inner workings shouldn't try it unless they're willing to make a mistake and throw it away, but ...
I loosened the screw. Not sure if it was a quarter turn or a half turn; I wanted to do more and have learned many times that "more" is not "better."
I have a cardboard box in front of the unit for hours now, and it is not saturated.
The factory setting, whether it be for all or some, is too wet. Loosening the screw that shows through the computer board has, for me, made the unit more tolerable. Takes an eyeglass-screwdriver to get it done, but if'n ya has the general know-how to investigate things, maybe it'll work for you.
Mar 15, 2007 | Sunbeam Ultrasonic 81696 Humidifier
Humidifiers Logo
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
