Question about Dell Inspiron 15 (N5050)
The bios in this system is not fully acpi compliant
When install win7x86 after installation shows blue screen : the bios in this system is not fully acpi compliant STOP (0x00005)
  • Dell Master
  • 5,631 Answers
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
Posted on Apr 28, 2015
2 Suggested Answers
Tech_Mania
  • 239 Answers
SOURCE: Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Posted on Mar 21, 2009
Asus eee pc bios in this system is not fully acpi compliant
These errors can be misleading. Try setting the BIOS to default.
Remove all USB attached devices.
Test one DIMM at time. One slot at a time. To eliminate possible bad RAM. Unplug PC. Opening case. Remove all RAM. Use static precautions!
Re-install Windows. Clean install works best. All data will be lost.
Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 09, 2012 | ASUS Eee PC 1015PEB 10.1 Netbook 1.66GHz...
Can't find updated ACPI Bios for toshiba satellite m45 s331I am Getting blue screen Bios in this system not fully ACPI compliant.
Upgrading the bios it will not fix the issue ..cause the blue-screen is either a unsupported setting or..it is a operation system issue ..So ..if you get the blue-screen when you boot up ..and does not let you to get into bios..It may be the ACHI (not acpi ..cause the acpi is the power management ) being enabled and not having the driver installed..and in this mode will not be able to boot and will give you that blue screen ..
To fox it ..just go to bios ..and look for the hard disk ..and in teh same category you will see the achi function ..and just disable the mode..and let it run as IDE..This way it will boot fine ..
Indeed the achi mode for a hard disk bus..is faster and if you do want to use it ..try to boot without the achi enabled..and install the achi driver in the system ..and after that enable it again and see if it works..
If it still does monkey business than it will have to be reinstalled ..and if you still want achi for hdd mode..you have to install the driver during the installation progress..as a 3rd party driver ..
In short ..try to make it run ..and do not mess with the BIOS ..cause you may end up with a broken laptop ..
Feb 17, 2011 | Toshiba Satellite M45-S331 Notebook
Dell 8300 not loading xp home with the blue screen of death
To resolve this behavior, contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
To work around this behavior, manually install the Standard PC hardware abstraction layer (HAL):
  1. Restart the computer to restart Setup.
  2. When Setup starts again, press F7 (not F6) when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Dec 30, 2009 | Dell Dimension 8300 PC Desktop
ACPI BIOS not fully compliant
w8000 a very old PC not supported by HP.
windows 2000 support ended like 15 years ago.. W2k. is gone. w2k only runs on very old pcs with very old ACPI
(power controls is that)
this PC is only supported with XP
never 2000.
HP tells you that if you looked.
park the 2000 disk or use it as frezzbee. IMO
https://support.hp.com/us-en/drivers/selfservice/compaq-evo-workstation-w8000/322279
id get w7 disk and use that, it might work.
but will cost you a license from MS,
about 5 times the value of w8000
why not just go here, and get used $20 w7 pc
save a bundle of case and grief messing with any legacy junk....avoid legacy junk and win.
http://www.pcdied.com/cheaper.html
a usa answers.... always...
Jul 19, 2017 | Compaq Computers & Internet
RESOLUTION
Mar 16, 2009 | Dell Inspiron 1100 Notebook
Windows 2000 setup
if this problem comes in blue skin ,then u must tel me about ur motherboard?
Sep 19, 2008 | Computers & Internet
Acpi complaint - reg
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Jun 23, 2008 | Intel Motherboard
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
41
Jan 17, 2008 | Intel Motherboard
Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Dec 04, 2007 | Microsoft Windows 2000 Professional for PC
Dell Inspiron 15 (N5050) Logo
199 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
