Question about Home
Pump and jet will not come on ,i have reasons to belive the circuit board is faulty. how can i obtain one
  • Alan May 11, 2010
    What kind of tub is this? Make, model and year would help in this matter.
  • 125 Answers
What is the model number of the pump? do you have any numbers off the old circuit board?
Posted on Nov 15, 2009
Coolant fan doesn't come on unless I run air conditioner.
"Coolant Fan" is not necessarily a common term used to refer to any particular fan in a standard HVAC system. Are you referring to the "Indoor Fan" that circulates the air within the living space???? OR are you referring to the "Outdoor Fan" or "Condensor Fan" that circulates the air across the outdoor coil ??
If its the indoor fan on an air handler that's not running unless its in A/C mode, it will be a faulty heating circuit fan relay on the main control board.
If its the outdoor fan and its a heat pump system the outdoor fan stops during the defrost mode so there is a slight possibility the system defrost board is faulty and stuck in defrost.
A little more information may help obtain a more specific answer.
Apr 14, 2015 | Heating & Cooling
Aeg error code e20
E21- Canister fill pump triac faulty.
Could be : wiring faulty or electronic board faulty
E22 - Triac "sensing" circuit for the canister fill pump faulty
Could be : Electronic board faulty
Dado
May 04, 2014 | AEG Dryers
Our 880 Marin hot tub is constantly running the jets on 1/2 of the tub as if the circulation pump is running. The icon on the control panel does not show the jets are on. When we push the button to turn...
sounds to me with a power surge you could have a relay on the circuit board not working properly.
You will most likely need to change the circuit board to correct the problem.
US Parts Center
Sep 22, 2013 | Pool & Spa
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
What could be the reason for tail lights not working on a 93 silvarado
There are only 2 reasons for ANY light circuit to not function properly.
1. burned out light bulbs
2. Open or shorted electrical circuits to the light bulbs
The MOST COMMON cause of an open circuit in Chevrolet trucks is faulty circuit boards or the tail lamp harness/socket assemblies. These circuit boards and harness/socket are available at most parts suppliers. (see pictures below)
Oct 30, 2011 | 1999 Chevrolet Silverado 1500
Pearl navarre whirlpool,pad only allows jets to cycle 20 minutes.will not cycle again . Sometimes will not activate jets at all . Is the problem with in pad or may it be in the main board? All other...
Sounds like there is a problem either with the board in your system or with the pump. if the pump has overheated then it will not come back on until it has cooled off. this is a long shot. I would guess there is a problem with a relay on the circuit board of your system.
Jan 30, 2011 | Whirlpool Home
I have a frigidaire model frs26lf8cw1. i had to replace the dispehenser board now when i plug the board in the ice maker will not stop dispensing ice, not sure what to do?
My kenmore started dispensing ice and water for no reason. After unplugging, I removed the cover from ice/water dispenser and discovered a burnt circuit board. Leave the board unplugged until you can obtain a good circuit board.
Oct 09, 2010 | Refrigerators
My jets on my topaz II won't shut off
maybe your filtration cycle is set to high.
check with your instruction manual on how to bring filtration cycle up and if showing FIL 8 or Fil C then this is the reason.
Is the spa up to temp? if not then spa is running all the time to try and heat.....
if not then may have a circuit board error or top side controller
Adam Miller
Service Manager, Canadian Spa Company, UK
Aug 12, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
Apr 08, 2010 | Pool & Spa
Home Logo
41 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
