Question about Panasonic KX-P2023 Matrix Printer
Flashing light no paper not working - Panasonic KX-P2023 Matrix Printer
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
Machine stopped - alarm light flashing
just saw this yesterday. remove the top rear paper guide. on the left side between the tractor feed and the input slot for the paper, there is a sensor flag that pivots. check for paper scrap caught under the flag. it prevents the flag movement, causes a paper out alarm.
Jul 13, 2012 | OKI MicroLine 420 Matrix Printer
Red light is blinking, What is the the meaning?
Hi, Here is the meaning of the flashing red light. Red probsolv.6.3.4.jpg paper light flashes Paper is jammed in the printer. Press the probsolv.6.3.5.jpg paper button to eject the paper. If that doesn't work, turn off the printer, open the cover, and pull the paper out from the front, including any torn pieces. Then turn on the printer, reload paper, and press the probsolv.6.3.6.jpg paper button. You can download the user's guide for this product from here. Good luck!
Mar 05, 2011 | Epson Stylus C86 InkJet Printer
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
Orange light is flashing
I cleaned out the printer by removing any access toner. Made sure again no paper was stuck and then it worked.
Apr 14, 2009 | HP LaserJet 2100 Printer
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
Feb 09, 2009 | Brother HL 5040 Laser Printer
The paper light flashes but there is paper in the machine.
there is a paper sensor in the paper tray , it will detect where paper is present or tray is empty. may dust cover the sensor, clean the dust on sensor and check where the sensor is working or not
Dec 23, 2008 | HP DeskJet 895cse InkJet Printer
Panasonic KX-P2023 Matrix Printer Logo
19 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
