Question about HTC Explorer A310e Black Android 2.3 unlocked phone
Why my htc explorer wont stop vibrating and cant power on.
It wont stop vibrating once i plugged in the battery. It wont vibrate if only touching the battery plat until the battery really inserted and pressing the positive side of the battery connector (what i mean is the one that kiss the battery plat or maybe the battery power receiver to the phone) while the battery in plugged in i cant stop the vibration by inserting a very thin screw driver touch the positive side of the power receiver. sometimes a tiny spark will happen. I cant power on it. sorry for my bad english.
    Master:
  • HTC Master
  • 515 Answers
Your phone have hardware problem so go to the service station to resolve
Posted on May 20, 2017
3 Suggested Answers
reeccoo
  • 55 Answers
SOURCE: HTC Touch Pro Won't Vibrate
So you having problem with vibrate capability?
Try this:
1. Make sure your phone not in charging (it won't vibrate for several phone like e.g. NOKIA)
2. Have you dropped it? If yes, immediately contact the customer service.
Hope this will help! PM me if there's any questions =]
Posted on Jul 07, 2009
  • 1011 Answers
SOURCE: My HTC Touch display goes blank and phone doesn't ring
Ok,
Good to read the detailed description. You said, the battery is full but did u checked the battery healthiness. Is it really full. Put the battery in another set if you have because the true picture will be in front when u check the battery on load condition. You can check the battery voltage but it might show you the full desired volt but without load. So, the better way has mentioned.
Tell me one thing that was it going off when u swap/filip ist screen. If this is the case, then u need to check the strip that connects the keypad of your phone with the LCD. This can be the issue...
good luck...
Posted on Sep 15, 2009
Why my htc explorer wont stop vibrating and cant power on?
dude its a serious problem...let it checked by any harware expert..we can only solve your s/w related problem not h/w...So go to a reparing shop.
May 16, 2014 | HTC Explorer A310e Android 2.3 Unlocked...
My htc hd7 does not stop vibrating
its a software problem Hard resetting the device will solve the problem.
Apr 19, 2013 | HTC Touch HD Smartphone
Htc evo makes crackling noises and vibrates lights up but wont turn on all the way
you either have a defective battery or a mainboard fault inside the phone.
Mar 08, 2012 | HTC EVO 4G Smartphone
Ok,
good luck...
Sep 15, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Vibration for text message
I use an HTC Touch. Hopefully the menu should be the same in Touch HD as per the Touch. Try this..
Start -> Settings -> in the Personal tab, click Notifications -> u might see 2 tabs -> select Notifications tab again -> select an Event (here it is incoming SMS) -> below you'll see the Vibrate option -> tick on it to enable it -> Select OK to save.
Hope this helps, If so, rate me.. thanks - billa..
Sep 06, 2009 | HTC Touch HD Smartphone
HTC Touch Diamond - Powers up and down while plugged in
from a power off device.
press and hold the center joystick button, and the volume down buttons.
dont leave those two!
and now power on the device. wait for a gray screen asking you to make a clean boot. press the volUP or volDOWN button and after about 5 minutes your device will make an hard reset (clean boot) and will restore it to factory settings.
good luck!
Aug 29, 2009 | HTC Touch Diamond Smartphone
Try this:
Jul 07, 2009 | HTC Touch Pro Smartphone
HTC diamond no longer Vibrates
The vibrate function of a phone is just a simple motor that pulses back and forth, creating a vibration. Just like any other motor, these can burn out. If the phone is still under warranty, you should be able to get it replaced. If not, an electronics repair shop may be able to fix it, but depending on parts and labor, you may be better off buying a new phone.
Mar 25, 2009 | HTC Touch Diamond Smartphone
HTC Touch HD - Vibrate function
The '********" is a little motor that spins with an offset weight. It sounds like the motor is stuck.
Feb 10, 2009 | HTC Touch Diamond Smartphone
Htc touch diamond vibrate problems
The instruction given in the user's guide are WRONG, which infuriated me. To perform a hard reset, hold down the power button and turn the phone off. Then, while holding volume down and the center button, turn the phone back on. It will give you the hard reset prompt immediately. Follow the instructions. I hope I saved you the stress I went through.
Dec 28, 2008 | HTC Touch Diamond Smartphone
HTC Explorer A310e Black Android 2.3 unlocked phone Logo
27 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
