Question about IBM EXP400 External SCSI Storage Enclosure p/n 17331RU (17331RUB) Drive Case
After switching off EXP400 drives and switch on again - the RAID controller cannot see drives. The message on RAID controller is "14 drives defunct"
SOURCE: raid w/ hard drive defunct
Well lets make some assumptions
1. You have a Raid 5 System
2. You only have 3 drives in the Raid ARRAY
3. Only 1 drive has failed
To fix the problem you should only need to Replace the Failed Drive
Then start the raid management software or bios
Rebuild the array
If you have more than 1 drive failed in a RAID 5, and still must recover the data it is possible. But very expensive. Still fixable however.
Posted on Oct 10, 2007
SOURCE: Cant create additional raid
Hi martyblue
Check this for specs:
http://www.redbooks.ibm.com/xref/usxref.pdf
The raid controller onboard is dual channel. Are you using a serveraid card as well? How have you configured the existing arrays? You may need to use the other channel if not already in use. Are the new drives ultra320 drives of same speed?
Posted on Aug 15, 2008
SOURCE: defunct of HDD in netfinity 7100 RAID
Download IBM ServeRaid , this software will allow you to see whats going on and correct issues
Posted on Jun 09, 2009
SOURCE: plugged in an external tape drive into scsi
This may due to HDD ID is conflict with external tape drive. Check and change the tape drive ID will solve your problem.
Posted on Dec 16, 2009
SOURCE: Troubleshoot ServeRaid problem on IBM x335 Box
The likelyhood that 2 drives fail at the same time is remote. I would first look to teh controller as the problem. Also, check the power supply. The only common things are the 5V and12V supply.
Dan
Posted on May 12, 2010
Feb 04, 2012 | IBM System x3200 M3 7328 Server tower ...
Jan 10, 2012 | IBM ServeRAID-7k Controller (71p8642) SCSI...
Feb 14, 2011 | IBM x3400 Server
Oct 13, 2010 | IBM x3400 Server
Sep 05, 2010 | IBM x3400 Server
Aug 15, 2010 | IBM xSeries 226 Server
Aug 06, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
Aug 01, 2008 | IBM xSeries 226 Server
Feb 23, 2008 | IBM eserver xSeries 360 8686
139 people viewed this question
