Question about Electrolux Washing Machines
I am after a picture of the motor wiring on an ewf1282 front load Electrolux washing machine. There is a spare yellow wire which comes from the ECU, but the only place it looks like it will attach to
If there are a bunch of pics for the internals of this washing machine that would be fantastic.
  • Official Brand Answer
  • 4,342 Answers
Good Morning Friend,
I understand that you are looking for a picture of the motor wiring for your Electrolux washer, model# EWF1282. This appears to be an Australian Electrolux dishwasher. I suggest contacting the manufacturer directly. They might be able to get you a picture of the motor wiring. Hope this is helpful.
-Best Regards-
WP
Posted on May 21, 2014
vest6
  • 196 Answers
SOURCE: installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Posted on Jan 13, 2008
  • 65 Answers
SOURCE: Bad wax motor in door lock assy. Where I can buy just wax motor?
TRY WWW.MARCONE.COM OR WWW.SEARS.COM UNDER PARTS. IT WILL GIVE YOU AN EXPLODED VIEW OF THE LATCH.
Posted on Jan 27, 2009
FitzOriginal
  • 842 Answers
SOURCE: The door will not open on my Electrolux washing machine
How much trouble do you want to go to?
If you just want to preserve the washing, then simply put it on another cycle tonight and that will keep it fresh until the callout turns up to fix it.
The next clever step is to power the machine off at the mains for 10 minutes. Depriving it of power MAY release the interlock door switch even if the cycle didnt.
Final attempt to get to it... Turn off power, unplug at the mains. drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
If you trust yourself NEVER to open the door in the middle of a cycle, the machine will of course function without a switch. Just so long as you recognise that you will flood the place if you do open it with water in. Also if you put your hand inside dirung a wash (Or worse still a spin) the power of the motor combined with the weight of the wet washing will rip the arm clean off a fully grown man, so if you doubt yourself or you have kids (or kids may visit) don't leave it like this.
Posted on Feb 09, 2009
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
  • 662 Answers
SOURCE: Whirlpool Duet HT GHW9300PW4 F 06 Error Code
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Posted on Jun 17, 2010
How to fix a E9F error code of EWF1282 FRONT LOADER ELECTROLUX WASING MACHINE
E9F - Communication error between main PCB and Inverter board.
Could be:
  • Faulty wiring between main PCB and Inverter;
  • Inverter PCB faulty;
  • Main PCB faulty
Dado
Feb 28, 2016 | Electrolux Washing Machines
Washer wiring diagrams
Heating element, washing motor and bearing must be earthed.
Dado
Sep 02, 2014 | Electrolux EW1200i Front Load Washer /...
Electrolux washer playing up!
Remove the top panel, there should only be 2 or 3 screws on the back of the panel, then slide the top panel back about 1/4 inch and it should lift off. Look to see if the belt has come off. Post your results back.
Jun 28, 2013 | Washing Machines
E9F code
Communication problem. Check the wiring between the Main Control Board and the Speed Control Board. Wiring bad, correct wiring problem. Wiring good, replace the Main Control Board. If the problem is not corrected, replace the Speed Control Board. Here is the part you need.
Oct 13, 2012 | Electrolux Washing Machines
I have a electrolux ewf1282 washing machine with a error code EH1 can you tell me what this is
Incorrect mains frequency-The power supply frequency is not within the configured limits.
May 18, 2012 | Electrolux Washing Machines
Electrolux ewf1282 wont fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jul 10, 2011 | Washing Machines
We have an electrolux ewf1282 and no matter what setting we put it on it will not spin, we have checked everything the product manual tells us, where to from here???
Sounds like the door switch is bad. Unplug unit and remove it to test. Somehow, jump the two wires together that you just took off. I believe they are yellow or orange. Make sure your two wires DO NOT go to ground on the unit. Turn your machine on and see if it runs through it's normal cycles. Another way to test the switch is with a circuit tester or ohm meter. Place one lead of your meter on one of the contacts you removed the wire from. Place the other lead where the other wire was connected. Press switch. Your meter should be reading 0 ohms or made a sound. If it didn't, then the switch is bad.
Jul 09, 2011 | Electrolux Washing Machines
I have an electrolux washing machine model atfb6700 front loading bought in 2008 that does not spin. It will turn on the wash cycle but the motor buzzes in both cycles. Is it the motor or motor boards?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is toasted...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Electrolux Washing Machines
E90 ERROR ELECTROLUX 1087 WASHING MACHINE
Error 90 is a common fault code in domestics within the Electrolux, Zanussi, AEG range. It's a wiring fault /connection normally between the printed cicuit board and wires. switch off power, remove lid, pull off each connector on board checking for clip holding the connector in place, one at a time, look for arcing marks, rub pins gently with clean cloth, tensinsion up clips in connector(delicately) and refit. having done this, test again with a wet load on spin, then a wash programme. Before dispairing check the motor coonnections.
Feb 28, 2010 | Electrolux EW1200i Front Load Washer /...
Changed main belt in machine and need to know
check earth wire is on motor, heater element and if metal tub fitted then this will be earthed aswell
Feb 16, 2010 | Electrolux AWW1017 Front Load Washer /...
Washing Machines Logo
88 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
