Question about Minolta bizhub 350 Black and White Copier
Developer unit for di 3510 is equivalent to bizhub 350?
    President:
  • Minolta Master
  • 1,447 Answers
Same developer
Posted on Jul 17, 2014
My bizhub 350 still says please wait even the fuser unit & lamp is ok. how do i reflash firmware?
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Feb 02, 2017 | Minolta bizhub 350 Black and White Copier
Hi. i have bizhub 350. my problem is the toner hopper is not spinning/rotating. hv already changed the developer,the toner replenishing box and the drum assy, whole unit. what seems to be my problem here....
Sir, the toner bottle motor assy. needs to be replaced. will take quite a bit of work to get to, recommended a service tech qualified on Biz hub 350. This series is well known for the toner bottle assy. fault as is the di3510 series prior to the Bizhub 200/300 series.
Mar 25, 2015 | Minolta bizhub 350 Black and White Copier
Code c255c after the f8 function
if you have a C2557 after changing F8 developer then your extra toner is too strong. Check your clutch adding toner, replace the small foam with an equivalent thickness, increase your toner and repeat a gain F8.
Feb 17, 2015 | Konica Minolta bizhub 350 All-In-One Laser...
Need to replace the drum on a minolta bizhub 350 copier
First get into service mode. Utility/Counter then meter count then check details. Then Stop 00 stop 01. Counters. Clear Drum and Developer. Then touch end do not exit all the way out of service mode. Turn off the machine using the main on/off rear of machine left hand side. Then remove the image cart. and replace the drum and developer. then turn machine on reenter service mode. Run F-8 found under Function. Do not print copy or allow fax to print before this is done. Or you will have to replace the developer again. So remove network cable and fax line if machine is as printer and FAX. after powering off
Jan 15, 2014 | Minolta bizhub 350 Black and White Copier
C 0001 code on Konica Minolta bizhub c350
Main Motor, recommend that you remove all of the image units, shake each one along its axis so that the developer in each unit is evenly spread across the units, so that not all the developer is sitting at one end, DO NOT STORE IMAGE UNITS UP and DOWN always lay flat. Might have already burned out the motor worse case the control board$$$$$$$$$$$$$$$$$$$$$$
Jan 08, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Please wait message on bizhub 164 machine at startup
When is the last time the drum and developer where replaced? Machine is waiting for certain issue to be conducted internally. so the machine giving you this message. Also check to make sure that the developer unit or drum cartridge is cleaned.
Jan 05, 2014 | Minolta bizhub 350 Black and White Copier
I have Printer refill powder in plastic bag, can i use it to refill some printers catridges or i need machine to make refill ink?
whats the model no of the machine? ink and toner are 2 totally diffrent things one is a powder and other is a liquid
Sep 25, 2013 | Konica Minolta 8936-488 Developer Model...
Cof32, blank copy on printing and copying bizhub c350
C0F32 is e developer problem,Imaging Unit ATDC (automatic toner density control) failure.
Try to add some toner and adjust the developer.
Enter service mode and adjust with F8
Apr 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Our copier is showing error code cof32
Sir,
Your image unit my have a problems has it been replaced recently, the starter my need replacing. What model is it BizHub, Di or EP? IF it is EP model then open and close front door to reset, if Bizhub or Di model turn on and off machine wait at least ten between on and off. If these dont work then starter/developer needs replacing and or ATDC sensor needs replacing
Feb 27, 2010 | Minolta DI-2010F Copier
Minolta bizhub 350 Black and White Copier Logo
32 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
