Question about Hotpoint Washing Machines
Hotpoint wmt05 just stopped. Sparks at top of machine. Now dead
Machine has been working fine. Made a "groaning" noise. Sparks at top of machine. Now DEAD ! Help please....
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
aborcass
  • 2651 Answers
SOURCE: groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
Posted on Feb 24, 2008
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
  • 200 Answers
SOURCE: Hotpoint ultima wt741 F11 fault code
HI
There are several reasons why a Hotpoint door could be jammed shut. One of them is the part you describe which is called the ******. With some older Hotpoint models, there is a cable that runs from the door interlock to the motor. When you operate the door catch or button, this part "pecks" down onto the drive belt or the end of the armature's shaft. If the drum is moving, the ****** will slip on the rotating belt or armature and disengage the door interlock. If the drum is not moving, the ****** meets resistance and the door opens. Therefore if the ****** has come off, or is loose, it can stop the door opening. When you attempt to open the door does this part move?
Other things that can stop the door opening are -
  • A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
  • If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
  • A faulty door interlock
  • The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thank you
Posted on Dec 06, 2008
onthejob5130
  • 640 Answers
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Posted on Jan 03, 2009
WHAT CAUSES GROANING NOISE WHEN SPINNING?
Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch Washing Machines
Mt WMT05 Hotpoint went mad whilst on spin, managed to find out that one of the suspension springs had broken, ordered some new ones and replaced both, it now spins ok but when put on wash (all the...
The tube goes to the pressure switch and to the bottom of the drum, if it is not connected the machine will continue to fill as the switch is not being told it is full and now needs to change to next part of wash.
Pressure switch is a circular unit located at the top of the machine and has a couple of wires to it.
Dec 21, 2012 | Hotpoint Wmt05p Wmtl79 Wmtl80 Washing...
Hotpoint wmt05 flashing door lock light
simple one this i would guess, there is a spring in the door latch/handle, part number C00097647, replace this part and it will sort your problem. Take the door apart, the handle/latch assembley basically lifts out and will be clear what to do when you get this far
May 20, 2012 | Washing Machines
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
May 28, 2010 | Roper RAX4233PQ Top Load Washer
Hotpoint wd420 clunking noises
Perhaps you are putting to much in it, poor machine, give it a break in its old age! All the Best -the Yeti PS leave room for the water!
May 17, 2009 | Washing Machines
My hotpoint aquarius wf250 won't do anything it lights up with wash symbol but doesn't fill or wash it doesn't make no noise or anything please help
open the top of washing machine and near the door on right side is a connector loose just push in and will work fine.
May 10, 2009 | Washing Machines
Hotpoint WMA35
Remove lower rear cover of washer, remove belt, undo 2 screws securing motor, remove motor wiring plug,, lever back motor and remove motor.
Remove carbon brushes at end of motor, and check for wear, if less than 8-10mm long, then replace them.
Clean armature with emery cloth or sandpaper before fitting new brushes, if it still does not work then the motor is probably faulty.
Plz rate my solution.
Thanks.
Jan 23, 2009 | Hotpoint WMA35 Front Load Washer
ML2250 Laser
Dead/dry fan bearing.  Either: * order a new fan and replace it  * peel off the sticker on the fan and add a tiny drop of sewing machine oil - I did and has fixed mine (not sure how long)
Pretty easy machine to disassamble without a manual as long as you don't force anything. Well engineered 2- 4 screws for each panel and some very mild flexing of panel clips required. Remove in order: back cover (ease past power switch); top cover - have to lift to about 30deg at front; front cover (unplug wire to light assembly, unclip top + push forward); side cover (note hooks on bottom; unclip top and push to rear).
Aug 24, 2008 | Samsung ML2250 Laser Printer
Groaning noise in Maytag 4000 washer
Feb 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
13 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
