Question about KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
Why am i not getting power to icemaker
I have a kitchenaid side by side with a modular ice maker getting no power to ice maker!
SOURCE: Kitchenaid side x side model#ksrp22fnss00
Bottom right hand rear of unit has valves which allow water to flow to ice cube trays. Possible cause, dirt in line or valve stuck closed. Disconnect power from unit, hook up a small 12 volt transfomer and force the valve to open and close a few times. Saved a bundle this way myself.
Posted on Jul 12, 2007
watugot
  • 290 Answers
SOURCE: Kitchenaid ice maker
Is it sticking all the way up in off position?If so there is a redesigned arm to stop this problem. Instead of just a wire arm, it has a plastic flap on the bottom that hinges. This keeps the arm from jumping into the off position when it cycles. Any whirlpool/kitchenaid servicer should have one and show you how to replace it. Takes just a few seconds. If it is sticking half way down or lower, then it is binding up somewhere. You should be able to raise it about 2" and it fall freely back into place. Post back if this is what is happening.
Posted on Oct 07, 2007
SOURCE: Ice Maker problem
Apparently lowering the temperature by 5 degrees in the freezer compartment will keep the input water tube from freezing. It is working fine now!
Posted on Dec 29, 2007
jumptrout51
  • 3361 Answers
SOURCE: Stand Alone ice maker leak
Your model number must be plumbed to a external drain.
You may have to install a condensation pump to do this.
Posted on Mar 10, 2009
SOURCE: ice jams in KUIS18NNJB Kitchenaid under counter ice maker
There are 2 sets of wires on the cutting grid that are perpendicular to each other. Electrical current passing through the wires creates heat that melts the ice. The first set cuts one direction, then the ice strips drop onto the second set that cuts the strips into cubes. Remove the cutter grid and check if the wires are broken. If they are, electrical current can't pass through the wires, so no heat. Restringing kits are available to fix this. If the wires aren't broken, you'll need a voltmeter to see if current is reaching the wires. If it isn't, then the transformer has likely failed.
Posted on Mar 11, 2009
How do you remove icemaker to check if water tube is frozen?
the ice maker is finished. get the ice maker model number and refrgerator model number and buy/ install a new one. It would be a good idea to replace the electric water valve to the ice maker as well.
Feb 07, 2014 | KitchenAid Architect Series II KSRJ25FXMS...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire Superba Ice maker - no water flow
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. For whirlpool and its subsidaries,you can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. For GE, you turtn the ice maker off, wait about a minute then turn back on, water should automatically shoot water in the icemaker. That will tell you the water valve is good and icemaker is bad, or the ice maker is good and the valve is bad if no water. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
Jun 06, 2012 | KitchenAid Superba KSBS23IN Side by Side...
Ice maker doesnt work
Note that the temperature in the freezer must be below 10 degrees F for the icemaker to cycle. The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
Jun 05, 2012 | Kenmore Side by Side Refrigerator
Kitchen aid ref. KSRX22FNST01; ice maker; 120 v. at the IM connector, 32 V. at the IM motor
May 14, 2012 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker not making ice
May 10, 2012 | Kenmore Side by Side Refrigerator
Ice maker quit workingon kitchenaid side by side bowfront
check to make sure yr getting water to inside of ice maker if you are then replace the icemaker you can order them from marcone or allbrands appliance
May 16, 2010 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid superba icemaker
HI thanks for the question On the ice maker you should have an metal arm thatlifts up &down Down means you want ice Up means the ice bucket is full if that arm is not there that will cause the problem if the arm is there make sure it moves up & down ok if it does Then you need a new ice maker or save money & when the bucket gets full turn off water at back of fridge to stop water from coming in thanksfor the question THe appliance doc
Sep 03, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker
By manually moving the ejector blades you have now broken the ice maker module. (The brain and the motor of the icemaker). Kitchenaid had a batch of thermostats that arent working properly in these Indoor ice makers. I reccommend getting an entire new IDIM icemaker. You will have the improved module whith stronger gears (however you still cannot manually move them) and the improved thermostat.
Nov 24, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels Logo
93 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
