Question about Logitech N700
Logitech N700 lapdesk with fan not working
I bought this tech N700 lapdesk with speakers and fan and the fan decided to stop working. I cleaned out any dust that might have been an issue, but nothing. I spent a lot of money on this lapdesk online and am wondering if there is a solution out there other than dumping it? Please help or advise.
  • Grognard
    Grognard May 19, 2014
    Hi Regina Kech, I want to help you with your problem, but I need more information from you. Was the fan working and now suddenly quit or has it been dead from the start? Second (and please don't take this the wrong way) are you sure the fan switch is in the on position? I only ask because I was surprised to see that it had even such a switch and that it's in a position where it could easily be turned off accidentally.
3 Suggested Answers
SOURCE: Hi, I have a logitech
Hi nidkap,
My name is Oliver Riemann and I work in the product marketing group for Laptop Accessories. I was disappointed to learn about your recent experiences with the Speaker Lapdesk - this experience is not what we would wish for our customers.
The issue you describe in your mail could have various causes, and our engineers are willing to investigate in order to be able to deliver the best experience.
But we want to help you now. I would be happy to exchange your lapdesk with a totally new one. If this offers suits you, please feel free to contact me via email.
Thank you,
Oliver
Oliver_Riemann@logitech.com
Posted on Oct 06, 2010
bronk50
  • 27725 Answers
SOURCE: I just got the Logitech
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might need to select stereo speakers
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Jun 18, 2011
Can't control volumn or mute button
The mute button is noting more than an on/off switch that electronically disconnects or blocks the sound signal temporarily. If both the Mute and Volume controls won't function then you have a power amp dysfunction to the speakers. Go to Tiger Direct on the internet and get a replacement system from the refurbished section at a good price.
Jan 14, 2014 | Logitech N700
Logitech z906 remote stopped working
Sometimes the battery terminals become pitted and don't make good contact, get a Q-Tip and rubbing alcohol to make sure it is spotless. If there is no change! take it to a TV tech. to verify it is the remote, if yes he may be able to repair it.
Mar 24, 2012 | Logitech Z906 Speaker System
I have just bought Logitech Z623 Speakers and connected with my computer. All Speakers work fine upto certain Volume and Bass level but One of the satellite Speaker ( Mostly Speaker with Volume/Bass...
try swapping the speakers around if the problem still persists either the speaker is faulty or
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
other than that you might have a warranty issue
hope this helps
Aug 08, 2011 | Logitech Z623
I just got the Logitech Lapdesk N700. It works but the speakers sound awful. They crack and pop and sound real distorted. I am running a Windows 7 Ultimate.
hope this helps
Jun 18, 2011 | Logitech N700
Klipsch THX subwoofer just stopped working. Speakers still work (sound awful without the sub). Fuse looks solid. Back of sub was hot.
Heat is the clue.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If you can gain access to the subwoofer driver, disconnect one side of it and see if the amp comes up. The driver miight have shorted.
If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 13, 2011 | Audio Players & Recorders
I just got my logitech N700. Every time I try to plug the usb cable into my computer, however, my computer shuts down. I tried injecting other things - my flash drive, my external hardrive, and my old fan...
Try shutting down your computer before you plug in your USB. As you may have a surge problem. Then plug in your N700, if this doesnt work You may have to goto PC world or your local PC dealer and ask them. Hope this helps.
Feb 27, 2011 | Logitech N700
The sound just stopped working
A precise make and model might yield more-specific answer.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 20, 2011 | Audio Players & Recorders
I bought the speaker lapdesk N700 and it worked only for 30 days or so now the sound is all distorted. How do I go about repairing, or replacing it or getting my money back?????
how distorted is it and when did it started to sound wrong was it while u were using the speakers or was it after u just booted up your system first time of the day?
did u check your wires if everything was all secured in place?
also if u have pets and they love to take a bite on your wires ive seen this before they could do that.
if its distorted is could also mean they are busted as in someone turned the music too loud for the
capabilities of the speakers and that would make the sound distorted,
those are my theories ...but since im not there to physically check its hard to be certain on those things
good luck
Oct 20, 2010 | Logitech Computers & Internet
Logitech N700 Logo
212 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
