Question about Optics
What reason would the check engine light just not come on other than the bulb being blown?
Check engine light dont work at all.
    Genius:
  • 1,224 Answers
Change its bulb reset dtc then check again to see if code comes up
Posted on May 17, 2014
By brake lights dont work the one in the back window works but the two at the bottom works?
try looking to see if the bulbs are blown if so replace them, check for loose connections, still nothing check the wiring, fuses
Dec 24, 2014 | 1998 Chevrolet Monte Carlo
Replased right front blinker bulb. when taking broken burnt bulb out of socket wires crossed i could smell somthing burning front bulb works now. but the rear running lights dont work and head lights
Get a multimeter check for DC voltage at the light sockets. No voltage means blown fuses. You can also use the multimeter to check the bulbs to see if they have somehow blown.
Dec 06, 2014 | 2001 Chevrolet Corvette
How can I get the "check engine light to go out" on my 1999 Ford Escort so I can get it inspected and they use computers that record the inspection directly to the MVD
What is the engine code?
Almost any part store will be able to read and clear codes. depending on what the code is, the light may stay off long enough to get an inspection.
Dec 30, 2012 | Cars & Trucks
Windows and power mirrors stopped working and interior dome lights stopped working.fixed mirrors and windows but interior lights still dont work when door is opened.
on some vehicles there is a switch that disables lights some are on dash some are on the overhead light. if only one bulb ck bulb, if all lights could also be fuse
Mar 09, 2010 | 2004 Jeep Grand Cherokee
Installed driver side headlight worked, an hour later both main headlights went out, when I went to check lights noticed that there was another headlight behind a little chrome cover that was out, could...
reasons bulbs keep blowning.your head light bulbs is halogen bulbs.dont touch with bare hands.the oils on your hands will make them over heat and blow.so use clean gloves on your hands when replacing the head light bulbs.if all is good.check alternator out put.it could be overcharging causing too much current flow through electrical circuit blowing out bulbs.use a digital volt meter hook it battery with car running battery voltage should be 13.5 to 14.5 volts. if it is 15 to 16 volts too many volts.alternator is faulty.due to lock out features turn off radio before disconnecting battery cables so you wont lose radio playing code.
Nov 24, 2009 | 2004 Honda Accord
BMW 328I Check Engine Light Bulb replacement.
You will have to pull the dashboard display out and check to see if the bulb has blown or has been removed for some reason.
Apr 06, 2009 | 1997 BMW 328
Sonoma,check engine light doesnt turn on
dont worry about it ,perhaps the bulb has blown ,if car runs ok leave well alone
Mar 20, 2009 | 1996 GMC Sonoma
My check engine light is not working
wow this one is 1 year ago. bulb could have blown .if it was bought used. it might not even have a bulb.when you buy a car turn on the car but dont engage the starter .check engine should be on and stay on untill you engage starter and should go out in couple seconds after car starts. you probley already got it fixed by now any way im new and starting with check engine light your my first .
Feb 21, 2009 | Cherokee Jeep Grand CD Changers - 10-Disc
My run lights dont trun on
Check for a Burned out Bulb on these Lights. I had one of these in School and it Did this. Had a Bulb Blown. Replaced it and they Started Working Just Fine. Please Rate My Response! Thanks!
Feb 01, 2009 | 1984 Oldsmobile Cutlass
Optics Logo
74 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
