Question about HP Color LaserJet 2600n Printer
Printing problems with Epsom DX4200
Printing was quite faded on low cartridges so replaced all of them.
Now printing is now virtually blank. have run a nozzle check 3 times but all I am doing is using up ink.
How can it go from faded but readable on low cartridges to virtually blank on full ones??
  • Val Brice Sep 29, 2009
    I have exactly the same prob, did you manage to get it fixed?
    President:
  • HP Master
  • 990 Answers
Hello sir; I believed that's installation problem, pull out each one and slide in again (push harder) see what happen.
Posted on Jun 23, 2009
Have just installed new ink to my Epsom Stylus sx215 but wont print, just blank pages
Ensure cartridge fitted 100%, and you have taken off cartridge protectors, but the Printer should tell you why it's not printing !
sound simple to replace ink cartridge, but it can be tricky.
s
Feb 14, 2015 | Epson Stylus Office Equipment & Supplies
Epson DX4200, all installed properly, new cartridges, monitor showing them full .. and they are as i have just replaced, yet still the printer goes through the motions of printing, yet i just get a blank...
Hello.
Just make sure any air hole stickers have been removed from the cartridges. They allow the ink to flow when installed and Non-Epson brand ones sometimes have a air hole cover to stop leaking during transit.
Hope this helps Regards GM
Aug 01, 2011 | Epson Stylus DX4200 All-In-One InkJet...
Printer 5510
If you use your printer occasionally, it might be that the print head on the cartridges is clogged. I don't know what was serviced, but if your cartridges haven't been printing for a while, that is surely your problem. You can try this:
  1. Try cleaning the print cartridge from the Maintenance utility by following the steps below:
    1. On the all-in-one front panel, press Setup (or Menu) repeatedly until "Maintenance " displays, then press Enter .
    2. When "Clean Cartridges " displays, press Enter .
    3. At the end of the cartridge cleaning cycle, a page will print. Examine the page to determine if the problem is corrected.
  2. If the problem still exists, clean the cartridge following the directions below in the "Clean under the cartridges and the carriage " section below.
  3. Verify that the ink cartridge is not low on ink by checking the estimated ink levels as indicated in the "Colors on printout are wrong or fade in and out while printing " section above.
  4. Replace the print cartridge for the color that is not printing correctly.
Mar 05, 2010 | HP 5510 4-in-one Printer
Epson dx4200 printing-NOT!!
then it might be problem with the drivers,,, can reinstall and check the epson drivers,, if not try the printer on some other pc to test.
Sep 29, 2009 | Epson Stylus DX4200 All-In-One InkJet...
Gradually stopped printing, first colors, then black. New cartridges no help.
check all the catridge installed ok after finding the gatridge ok if the problem not solved , then uninstall the printer driver and restart after restarting the machine then again reinstall the printer driver properly
May 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Epsom stylus all in one dx7450
press 'Control' + 'P' on a page (as tho you want to print)
click 'Maintenance'
there you'll find various options to clean heads etc, that should do it. tho it does deplete your inks considerably each attempt. & you'll probably find it needs more than one clean.Good luck!
Jun 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Printer printing mainly red.
That is a cartridge or a head problem.
Try replacing the whole color cartridge set.
If that does not help, perform print head procedure from printer utilities a couple of times.
If still no luck, then you need to replace the printhead.
Jun 04, 2008 | Epson Stylus DX4200 All-In-One InkJet...
Prints a few lines, then blank
This is worth attempting to discuss with Lexmark's Tech Support line. Or take a look at www.fixyourownprinter.com
May 17, 2007 | Lexmark X5150 All-In-One InkJet Printer
HP Color LaserJet 2600n Printer Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
