Question about Maytag Washing Machines
What year is lat9235aae - Maytag Washing Machines
    Problem Solver:
  • 16 Answers
The washer's serial number is needed to find out it's age
Posted on May 17, 2014
How old is a 10 year old dog in human years
About 70, though it can vary from breed to breed.
Jan 07, 2017 | Dogs
Onkyo just shuts off...
check whether any loose connection in the board of the unit.
Aug 15, 2008 | Onkyo TX-SR605 Receiver
Serial#854480 model94 Winchester rifle what year was it made
serial SI100808419 Samick guitar does it exist
Mar 11, 2012 | Computers & Internet
Maytag top load washer model LAT9235AAe will only run when dial turned to final rinse position.
HI. this is a fairly simply fix here. the timer mechanism is damaged. The timer motor is not providing proper rotation, that is required for forward advancement of the cycle selected. It should be replace asap, if possible.
Sep 06, 2009 | Maytag Washing Machines
Guranteeofasustekmotherboard
http://support.asus.com/service/service.aspx?no=231&SLanguage=en-us
Motherboard 3 Year Since 2000/1/1 onwards Notebook 2 Year Since 2002/2/1 onwards Portable PC (Degatto PC) 1 Year VGA Card 3 Year Since 2001/1/1 onwards (3 year warranty)
Prior to 2001/1/1 (1 year warranty) CD /DVD /CD-RW /DVD-RW Drive 1 Year Server 3 Year 3 year warranty coverage on ASUS' full system. Applicable only to components with genuine ASUS label sticker installed on ASUS Server. Warranty period is determined by the serial number on ASUS Server. Wireless Products 2 Year PDA 2 Year Since 2003/2/18 onwards
Dec 27, 2008 | Computers & Internet
C program
See the Following Program
Leap Years
Def: A year is a century year if it is divisible by 100.
Def: A year is a non-century year if it is not a century year.
Def: A year is a leap year if it is a non-century year that is divisible by 4, or a century year that is divisible by 400. Nothing else is a leap year.
In a source file named leapyears.cpp, write a program that will prompt the user for the starting year and ending year for a range of years and print to the screen all leap years in that range, 5 years per line. You must write a separate function called isLeapYear that takes a year as a parameter and returns whether or not that year is a leap year. Your main function will call the isLeapYear function in a loop for every year within the range delineated by, and including, the starting and ending years.
Help with Code Tags c Syntax (Toggle Plain Text)
  1. #include <iostream>
  2. using namespace std;
  3. bool LeapYear(int y)
  4. {
  5. return ( y % 4 == 0) && (y % 100 != 0) || (y % 400 == 0);
  6. }
  7. double isLeapYear(double x)
  8. {
  9. if( x > -10000 && x < 10000)
  10. return x;
  11. }
  12. int main()
  13. {
  14. int x;
  15. cout << "Please enter start and end of a range of years: ";
  16. cin >> x;
  17. if (isLeapYear(x))
  18. {
  19. if (LeapYear(x))
  20. cout << x;
  21. }
  22. }
The One More Sample Of the Program
C program to check whether a year is a leap year or not.
Code: C /*
** C program to check whether an entered year is a leap year or not
** @author: Pradeep
** @date: 02/12/06
#include<stdio.h>
int main(void)
int year;
printf("Enter the year: ");
scanf("%d",&year);
** The logic is that the year is either divisible by both
** 100 and 4 , OR its only divisible by 4 not by hundred
if(year%400 ==0 || (year%100 != 0 && year%4 == 0))
printf("Year %d is a leap year",year);
else
printf("Year %d is not a leap year",year);
return 0;
If Not Satisfied Just put the Program name in Google and Search
Sep 10, 2008 | Computers & Internet
MAYTAG LAT9235AAE TOP LOAD WASHER WILL NOT WORK
Pt, Should be a yellow wire from the water level switch according to the diagram I have. See if it has 120V to motor when full. Just take it to ground. Same with the lid switch in closed position, it shows here as yellow, but could be grey, these diagrams are not always accurate. I think you have a level switch or lid switch problem. Check for voltage to the motor when it should be agitating. Catriver..post back.
Oct 01, 2006 | Maytag LAT3600A Top Load Washer
LAT9235AAE
Put the tube back on switch and remove other end from tub. Then blow and see if switch is working
Sep 23, 2017 | Maytag 22 Cycles Topload washer, SAV365Z
Maytag LAT9235AAE fills with water....
Pt, as long as you verified the lid switch is good, do this simple test. Get a piece of hose the same size as the one going to the pressure switch, connect it and blow into it. See if it starts agitating. If it does, there's your problem..Catriver post back.
Sep 27, 2006 | Maytag 22 Cycles Topload washer, SAV365Z
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
