How can i get a wiring digram for a 2 ton electric heating cooling for moblie home
I need a wiring digram for a 2 ton miller heating cooling for a mobile home
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 76 Answers
Google Miller.com Im sur they can help
Posted on May 17, 2014
Find the thermostat for a AUX split unit?
you can get one that has two heat and one cool at a lowes aor home depot or a heat and air company;
Sep 13, 2014 | Heating & Cooling
Wiring digram
Depending on the age of the unit and the vehicle, it should be color coded. So just transfer the wires color for color to the new connector.
Jan 22, 2014 | Alpine Moblie Media Solutions CDE-102
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
Jun 29, 2017 | Goodman GMS90703BXA Heater
Whats the cooling capacity
1 ton of cooling equals 12,000 BTU
2 ton of cooling equals 24,000 BTU
3 ton of cooling equals 36,000 BTU
1000 sq ft home needs about 30,000 BTU of cooling..... if you live in Kansas USA.
This is basic cooling. Hope this helps.
Mar 26, 2011 | Heating & Cooling
I have an old Miller 3 ton heat pump. It will work fine sometimes but when it decides not to work i can go outside and press the power contactor and the unit will come on as long as i hold the contactor...
it sounds to me you need just a really good tune up maybe a new contactor retest your low voltage what do you have from common to 24 volts it should be 27 volts if you test each wire you want get 24 v it will be like 7 or so
Sep 22, 2010 | Heating & Cooling
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
No heat need a wireing diagram 1997 package unit
impossible to get wiring diagram without model or manufacturer
Nov 21, 2009 | Heating & Cooling
Reduce blower speed
Motor speeds on the blower are always remember black is high, blue in med. and red is low sometimes blowers are 4 speeds but the main colors are the black blue and red. Now where to change locate the wires coming from blower to a box or control board. control board has setting for heating and cooling speeds for the blower. You might see blue on heating which would be medium speed so take the red off park terminal and change places with the blue. Now if you have a fan control switch it looks like a dail in the middle of the furnace with numbers on the face with pointers set at the numbers. follow the wires from there to the electrical box and open box. find color of blower and switch be sure to cap off the wire you change. Wire nut would be good.
Nov 19, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
