I have a 2000 Mercury Sable OHV 3.0L V6 engine. I drive the car every day to work without turning the AC on and it does fine. As soon as I turn the AC on, it starts to over heat. I already changed the thermostat, and temperture switch. I suspect the next thing I have to change is the compressor. what else can it be.
  • 24 Answers
Your A/C Works, so its not the Compressor. Don't Ask, change the water pump and do also a pre-fllush, with a good Radiator Flush, and do a full flush-out of the cooling system that will take care of the entire Engine Block and water ways, in the process, look carefully at the Top and Bottom Hoses going to the Radiator, if swollen near the clamps or any part, change them in the Flush Process, and do not use water when filling-up, use a good pre-mix like Prestone and similar brand Coolant. I am pretty sure, it is the service it may have needed for the long haul again!
To protect, and restore your Vehicle's Engine-Transmission-Gearbox-Power Steering-Differential etc. We can Restore (DIY), them and protect them for life, without failure, burn less fuel, greater combustion, better lubrication, Power, and become newer with the more you drive, please contact us: razorinnovations@ymail.com
'The Science of Restoration & Protection.'
By: www.razorinnovation.com
Posted on Mar 22, 2013
  • 434 Answers
Is the fan runnung? Also could be the water pump. Running the A/C puts alot of extra strain on the motor.
Posted on Jun 24, 2009
I have a 2000 muery sable L's prem I've been driving it for 5years wit power steering I just need help on wat size belt will I need to bipass the power steering pump .
Mercury Sable - Wikicars
wikicars.org/en/Mercury_Sable
The Mercury Sable is a Large Front or All Wheel Drive Luxury Sedan produced by Mercury ... A major sheet metal and interior redesign occured in 2000, softening some the .... For both 3.0 L and 3.8 L V6 engines, the drive belt system became a .... Also a new trim level was intoduced the LS Platinum Edition, it featured Satin ...
Dec 16, 2015 | Cars & Trucks
Does a 1996 mercury sable and 2001 ford taurus have the same engine
Its possible. In this time span Ford used two different motors, the overhead valve (OHV) Vulcan V6, and the Duratec 24V V6, which will bear the 24v DOHC badge on the front fender.
Aug 31, 2011 | 1995 Mercury Mystique
!999 Mercury Sable, 3.0L OHV - I just put Autolite app104 double platinum spark plugs in, Autolite #96837 ignition wire set on, and an air filter. All was fine for 20 miles and then my "Service Engine...
Computer has detected a fault--may or may not relate to the work you did. Please get a diagnostic scan of your OBD II connection and report trouble codes back to us. If you are in US, Autozone and Advance, among others, have free scanning service. We need the codes to diagnose.
Sep 30, 2010 | 1999 Mercury Sable
Need serpentine belt diagram 4 merc sable 3.0
...are under hood, a diagram on top of radiator support.
Feb 12, 2010 | 2004 Mercury Sable
No oil pressure, camshaft position sensor error,
Yes, the sensor is in small housing the goes in the hole where the distributor used to go. That also drives the oil pump so don't drive it you'll ruin the engine. It's located down under the throttle body, near transmission end of the engine.
Jan 04, 2010 | 1997 Mercury Sable
Drive belt diagram for 24V DOHC engine
re: 1996 Mercury Sable, ohv V6 . . . . A mechanic diagnosed the cause of engine failure to a bent piston rod as a result of someone having poured water directly into the engine -- is that possible? Further, research showed evidence that water had been leaking past the head gasket directly into the affected cylinder. Additionally, the heads had to be resurfaced.
Jun 25, 2009 | 2000 Mercury Sable
Overheating with AC on
check a/c fan operation,does it com on when sysetm is switched on?
Jun 23, 2009 | 2000 Mercury Sable
1989 Mercury Sable, 3.0L V-6, Auto Trans. Engine Idles at about 2000 RPM.
Check your vacuum hoses (They are 3/8" Rubber hosing on the right side of the engine, you will need to remove the air intake piping (Also remove the throttle body to make accessing them easier) This is the #1 cause of high idling in the 3.0 OHV and 3.0 DOHC sable engines.
Jan 17, 2009 | 1989 Mercury Sable
2000 Mercury Sable double overhead cam Transmission problem
manual para reparación cadena de tiempo de motor v6 3.0 sable 2000
Oct 18, 2008 | 2000 Mercury Sable
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
