My washing machine ARISTON AVTF 129 keeps displaying error code F-16. What's wrong?
Minutes before he was failing the tap water wall. Program 3: fills a little water, the strip, and then does nothing more .... the display fails 16
  • 105 Answers
SOURCE: error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
Posted on Jan 02, 2008
mewms_14904
  • 1027 Answers
SOURCE: Ariston washing machine front loader
You could check the pump, open and drain, clear anything out of the pump, next turn off and unplug the mains cable, wait 40 secs and connect mains and turn back on.
Posted on Apr 11, 2008
SOURCE: ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Posted on Jul 11, 2008
ginko
  • 19396 Answers
SOURCE: error code on display panel
F-12 is a drain problem.
Check if the drain hose is free, if cycle stops and gives you f12 without draining the water, there is a problem with the drain system.
The Hotpoint should have a removable paner at the back on the lower side. The panel gives access to the pump. If cleaning the drain hose does not solve the problem, the pump must be removed and cleaned or replaced.The repair should be done by a technician.
Posted on Dec 14, 2008
hbsurfdawg
  • 95 Answers
SOURCE: ariston avxl 129 washing machine has stopped working.
This washer does not have a good track record. There are many many complaints out their on this brand in general. It is also not a cheap purchase.
1st. Suspect is the mother board followed by the motor.
Posted on Nov 20, 2011
Aquatis AQXXF 129 h. what is the error code 08?
It means "heater relay cannot be activated". Troubleshooting guide says to tap the relays to try to unjam them. If that fails, replacement of the main control board is necessary. These washers apparently have a propensity for stuck relays on the newer units.
Aug 15, 2015 | Ariston Technologies Washing Machines
Ariston artxf 129 error f02
F02: Blocked Motor, Short-circuited/Open Tachometry
Overhaul CNE
Overhaul Motor connector
Control CNE Continuity/Motor Connector
Control Motor Windings
Control Tachometry Windings
Replace Card
Dado
Jun 04, 2014 | Ariston Technologies AW 129 NA Washer With...
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
  • The water inlet hose is not connected to the tap.
  • The hose is bent.
  • The water tap is not turned on.
  • There is a water shortage.
  • The water pressure is insufficient.
  • The START/RESET button has not been pressed.
Dado
May 29, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston washing 125 is flushing h2o on the screen
displayed).
• The hose is bent.
Dado
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
displayed).
• The hose is bent.
Dado
May 24, 2014 | Ariston Technologies Washing Machines
WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
Error code h20
displayed).
• The hose is bent.
Dado
Mar 26, 2014 | Ariston Technologies AW 129 NA Washer With...
Ariston h20 errors
displayed).
• The hose is bent.
Dado
Jan 14, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Error messages on my Ariston AVXD109
displayed).
• The hose is bent.
Dado
Sep 07, 2008 | Ariston Technologies AWD121WH
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
