Minutes before he was failing the tap water wall
SOURCE: error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
SOURCE: ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
SOURCE: error code on display panel
F-12 is a drain problem.
Check if the drain hose is free, if cycle stops and gives you f12 without draining the water, there is a problem with the drain system.
The Hotpoint should have a removable paner at the back on the lower side. The panel gives access to the pump. If cleaning the drain hose does not solve the problem, the pump must be removed and cleaned or replaced.The repair should be done by a technician.
SOURCE: The Ariston ATVF 129 wash machine do not work and post F-02
F02 is a indication that the motor has jammed, and or the tacho has come loose or broken.
The tacho is the magnet at the end of the motor away from the pulley., check this first, you may have to have a new motor fitted.
Plz rate my solution.
Thanks.
SOURCE: Ariston 1636 f/l washing machine not draining properly
you need to clean the water passage at the drain hose.
