Question about Toto Aquia II Dual Flush Toilet
How do you unscrew the toilet buttons on a Toto dual Flush toilet?
kachbibi1
  • 979 Answers
SOURCE: I purchased a Toto Aquia
If this is one of those models that most people have, the valve that shuts the incoming water off when the tank is filled is probably bad. It only costs about 8-10 dollars to replace. This valve is actually a stem or tree shaped device.
Posted on Jan 28, 2009
  • 659 Answers
SOURCE: Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Posted on Mar 21, 2009
SOURCE: Push Button - Have to Hold Down Button
I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
Hope this helps
Posted on May 02, 2009
gypsycat00
  • 224 Answers
SOURCE: toto toilet, flapper doesn't stay up long enough to flush
One of two things is the problem. First, make sure that you have a tight chain with little slack. If there's too much slack, the flapper won't catch in the passing air to stay up. Second, the flapper is not correct for that style of toilet. You might want to look into purchasing a new Kolby filter that has a removeable cone in the center. Move that cone to 12 o'clock to allow the maximum amount of water to run through the flush valve. If the flapper you have now is flat, it needs to have a cone in the center on the underside.
Posted on Jul 10, 2009
SOURCE: toto toilet
my toto toilet seems to pulse when filling. Once full it i fine.
Posted on May 28, 2010
Invisi Series ll Round Dual Flush Plate & Buttons
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck
Jun 09, 2014 | Toto Aquia II Dual Flush Toilet
The dual flush push button flushing unit on my Toto cistren is not working
the connection rod under the lid is broken or not making the connection just lift the lift to see.
Oct 03, 2013 | Toto Aquia II Dual Flush Toilet
What is the easiest way to unscrew the flush plunger
You can get one from lowes or HD. If not ,the mfr has them. This will make lol the difference.
Feb 26, 2013 | Toto Aquia II Dual Flush Toilet
Cannot remove the lid
Hi and Wlecome to FixYa. I am Kelly
Unscrew the flush plunger assembly on the very top of the tank. It unscrews counter clockwise and then lifts out. Then you can lift off the tank lid.
When you go to put the top back you will have to align the flush pin gears in the slot.
If your talking about the seat.... then there are 2 nuts underneath the water closet at the back that must be removed.
Thanks for using FixYa.
Kelly
May 06, 2010 | Toto Aquia II Dual Flush Toilet
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
I purchased a Toto Aquia II Dual Flush Toilet, around a year ago. No problems until now. The toilet won't flush. It doesn't appear to be running at all.
Jan 14, 2009 | Toto Aquia II Dual Flush Toilet
Toto Aquia II Dual Flush Toilet Logo
87 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
