Question about Sennheiser HDR 120 Consumer Headphones
I have Sennheiser 120. Set it up right. One side or the other comes in clear. Never both sides at the same time.
Brand new. Made sure put together right.
  • 957 Answers
I have a set as well but the batteries were weak and it was doing the same thing when they were new. Replaced with good batteries and that was the problem. if you try this and they still don't work then just return it for a replacement
Posted on May 17, 2014
    Top Expert:
  • Sennheiser Master
  • 35,601 Answers
Check for a poor connection at the device end.
Help with Simplicity pattern 3894 Top C 2.With RIGHT sides together. 3.With RIGHT sides together. It is not clear on how to put RIGHT sides together on 2. and 3.
Just guessing here. Put the front & back pieces together with the rights sides facing each other. Stitch the shoulder seams, then stitch the side seams.
What Does Right Side Wrong Side Mean
Right Sides Together
Jun 18, 2016 | Simplicity Sewing Machines
Hearing from Left Side only
Sounds defective to me.. Most stores have a 30 day return policy. After 30 days contact the manufacturer.
Mar 02, 2014 | Sennheiser Mm400 Bluetooth Headset
Left headphone not working
what is the source of the audio? I would start by checking that first. switch sources to see if the transmitter is the problem if the transmitter is only getting the right side signal, that's all you'll hear...hope this helps!
Jun 13, 2012 | Sennheiser HDR 120 Consumer Headphones
Adjustable strap (left hand side) is broken. Need to purchase replacement part.
its a complete set with top lead also, available with us but shipment from here takes min12 days, cost is 40us$, transfereble through westernunion money,
Jun 28, 2011 | Sennheiser HDR 120 Consumer Headphones
I have the RS120. It worked ok for about 2 years and then the right side stopped working. The left side works just fine. I opened up the sides and it seems that there is no broken solders or anything...
well it seems your right earpiece is started to get broken...clearly saying that the coil has static and would result to an open coil.....try to replace with a new one...good day...
Feb 12, 2011 | Sennheiser RS 120 Consumer Headphones
Sounf come thru the right side but is silent in the left headphone
Hi,why sounds comes out from one side and the other side silentis because,the wire inside the speaker has cut and it needs to be soldered back with a soldering iron and a lead.
Sometimes it might also be from the speaker itself if it is damaged.
When you solder back the place that has cut,problem solved.
Thanks for using fixya....
Oct 20, 2010 | Sennheiser HDR 120 Consumer Headphones
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
My right side head set has no sound, left side head set is fine. there is balance control.
maybe the right side of your headset encounter disconnecting of his wire try to open if and reconnect again or replace the wire
Jul 05, 2009 | Sennheiser RS 120 Consumer Headphones
My sennheiser 120 headphones are wearing out. After much use.
You can buy the HDR 120 model which is basically the headphones lone
These will work with the base in conjunction with the set you have now.. or as a replacement
You can also buy replaceable ear cups for less than 20 dollars (check the Sennheiser website)
Finally you may want to replace the rechargeable batteries in the headphones you have
Just make sure you replace them with the exact type.. I believe those are NiMh AAA
Pop them out and go to any Battery Plus or Radio Shack.. a new set probably run you less than 7 bucks
My point.. for less than 30 dollars you can have your old headphones working and looking like new ones
Give the new batteries an overnight charge before using them
Good luck
Jan 03, 2009 | Sennheiser RS 120 Consumer Headphones
Sennheiser HDR 120 Consumer Headphones Logo
443 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
