Question about Whirlpool Washing Machines
Whirlpool error 8
Hola te comento el lavarropa lo prendo y empieza a carga y la los pocos segundos empieza a desagotar el agua y vuelve a carga de nuevo y vuelve hacer lo mismo y despues hace tricki tricki y no arranca el motor de lavado
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: CADA VEZ QUE EMPIEZA
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$%%
Posted on Sep 21, 2010
Hola tengo un Toyota Camry 2007 todas las Hola
posiblemente tenes roto el sensor de velocidad o los cables
Sep 08, 2014 | Toyota Cars & Trucks
No enciende solo tira una luz anaranjada atras de la carga
Hola:
1.- Desmonta la bateria (por debajo de la Laptop tiene, generalmente dos seguros, tira hacia afuera y se soltará la pila).
2.- Desconecta el cable de alimentación de la Laptop (eliminador).
3.- Intenta encenderla, dejando presionado el botón de encendido durante 15 - 30 segundos.
4.- Conecta solamente el cable de alimentación (sin bateria).
5.- Presiona el boton de encendido en forma normal.
Estos pasos sirven para descargar todo el circuito electrónico del equipo y/o desbloquearlo por alguna posible sobre carga eléctrica. Ve si funciona.
Si no enciende, intenta lo siguiente:
1.- Desconecta el cable de alimentación y batería.
2.- En la parte de abajo de la laptop, localiza una tapa con un ícono identificador tipo chip; desmóntala liberando el ó los tornillos.
3.- Retira el ó los módulos de memoria, jalando los seguros laterales de cada memoria. Tómala por los bordes.
4.- Limpiar o lijar los pines (contactos) de la memoria. Puedes usar un borrador de lápiz o una brocha impia y pequeña.
5.- Instalar un solo módulo de memoria, si fuera el caso.
6.- Encender la laptop sólo con el cable de alimentación.
Este procedimiento corrige una posible falla de lectura en la memoria que impide realizar el POST del equipo correctamente. Ve si funciona.
Espero y ayude. Gracias
Jan 31, 2011 | Acer Aspire 3680 Laptop
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Tengo un refrigerador GE gs6shaxks01 y no frabricando hielo...que hago/
CAMBIALE LA VALVULA D AGUA O EL ICE MAKER. VALVULA DEL AGUA ESTA ATRAS DEL REFRI. EN LA PARTE DE ABAJO SIGUE LA LINE DE AGUA. EMPIEZA POR LO MAS BARATO. NO TE VA A COSTAR MUCHO.( LA VALVULA) SUERTE. DEJA TU COMENTARIO SI TE SIRVIO ESTE PEQUENO CONSEJO GRACIAS
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cuando prendo el reproductor se apaga y lo prendo y se vuelve a apagar y asi hasta que lo sucecivamente bloqueo
Descarga el firmware de la pàgina de soporte de philips y actualìzalo. Eso deberìa reiniciarlo a los valores de fàbrica. Posiblemente pierdas los datos que tengas en la memoria del reproductor.
Nov 04, 2009 | Philips GOGEAR SA6045 MP3 Player
Tengo una camioneta isuzu y se acelera y
Hola Ruben
No estoy seguro, pero tengo un Amigo 90 que le pasa lo mismo.  Según creo el problema está en los controles electrónicos de las válvulas (esos aditamentos que están a la izquierda del carburador, segun lo ves desde el frente, sobre la salpicadera derecha del auto)
No se como se corrige el problema.  Supongo que cambiando los controles de las válvulas.  Una cosa que puedes revisar es que las mangueras que comunican el carburador con esas piezas que te menciono no tengan entradas de aire por grietas por resequedad.
Si alguien más sabe una solución mejor, espero con gusto su respuesta.
Yo quisiera cambiar el carburador por uno 100% mecánico mejor
Oct 03, 2009 | 1993 Isuzu Amigo
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Como le quito el password al bios
para sacar la password de la bios de la maquina solo tienes que abrir la maquina, al lado de la pila en la placa madre hay un jumper(un plastiquito que sirve de conexion)lo tenés que cambiar al 2-3, esta gralmente en el 1-2, osea lo sacas, lo pones en el 2-3, prendes la maquina unos segundos, la apagas, vuelves a cambiar el jumper a la posicion 1-2 y listo tu bios queda borrada, ahora solo tienes que entrar a la bios y configurar tu disco duro, la hora, etc,etc , si no hubiera tal jumper, entonces directamente sacas la pila por unos segundos, la vuelves a poner y listo,
Jul 15, 2009 | Toshiba Satellite L25-S119 Notebook
Hola tengo una camara webcam creative live, cambien de computador y no me lo acepta que puedo hacer gracias por tu ayuda
hola melivaob...
aquí tienes un enlace a la página de drivers para webcams de Creative, no creo que el modelo que tienes aparece en la lista principal, pero abajo de todo hay otro link que te lleva a otra página donde puedes elegir entre muchos... pero muchisimos!
a la derecha de la página principal hay un elace encima de los imagenes de los cams que pone 'aprende a identificar su producto'... si la segunda página te parece difícil... vuelve a la primera y siga el enlace para poder saber exacatmente lo que buscas.
lo haria por ti, pero no tengo bastante información para hacer la búsqueda.
espero que eso te ha ayudado, y avisame si tienes alguna otra pregunta...
bru*
Feb 02, 2009 | Creative Labs WebCam Live!
Ayuda
Te recomendaria que utilizes un transformador variable para que puedas hacer mediciones del voltaje que alimenta la seccion horizontal. Me parece que la seccion horizontal esta recibiendo mucho voltaje y es cuando se activan los circuitos de proteccion.
Si usas el transformador variable empieza con 80VAC y mide la DC en tu TV, si en la entrada de el regulador de voltaje tienes mas o menos 130VDC a la salida tienes lo mismo, el TV te funcionara. Despues incrementa es voltaje a 100VAC y vuelve a hacer las mediciones.
Si despues de incrementar el AC a 110VAC el TV hace lo mismo, trata de medir la DC en la salida del regulador de voltaje. El voltaje aceptable seria de 130VDC a 135VDC.
Suerte.
Jan 16, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal De
