Question about Husqvarna Rose
Why is it making a strange noise when I sew?
I have rethreaded the upper thread and the bobbin but it still sounds strange. The noise appears to be coming from the upper thread guides. It is a clicking sound.
  • 82 Answers
You probably need to have an authorized Viking repair person check your machine.
Posted on Feb 09, 2015
  • 192 Answers
SOURCE: Designer 1
Please, take this machine to an authorized technician before you attempt to set the timing on your own. An authorized technician will have a device to quickly tell you whether or not the timing is incorrect. If you change the timing yourself and that isn't your problem, you will spend far more money getting 2 problems fixed than the one original problem.
If the machine is making what I describe as a chattering sound, you may be able to clean the bobbin case and the ledge that it sets on and the problem will go away. This bobbin case should be operated with no lubrication. Some repairmen recommend " a drop of oil to make it run quieter". This generally makes it chatter louder. If there is any lube on the bottom of the black bobbin case, wipe it off and wipe the ledge that it rests on.
By the way, if the needle is hitting the raceway, you will be able to see the marks where it is hitting. In a Viking machine, this is normally caused by the "needle to hook clearance", not timing.
Posted on Feb 19, 2008
  • 3 Answers
SOURCE: will not pick up lower thread
DId you check for lint or thread fragments under the plate? This can cause all kinds of problems. Bush out any such materials. See if that helps.
Posted on Jul 23, 2009
  • 152 Answers
SOURCE: bobbin thread gets bunched up and loud clicking sound
The problem is never the bobbin when you have this problem. It's the top thread. Take the thread off the top of the machine and rethread the top. Make sure the small tension dial is on 4 or 5 (the larger dial on the front left is for the pressure on the foot, not the thread tension.) After you thread the machine, put the pressure foot down but NOT on the thread. Then pull gently toward the back of the machine. When you do, the needle should bend slightly backwards before the thread comes through the machine. If it pulls with no resistance you could simply have "fluff" or remants of thread between your tension discs. If you do, put the dial on zero and using an old needle, clean between the discs and try threading the machine again with the "pull test" I described earlier.
No tension on the top of the machine, lets the bobbin tension win and it pulls all the thread to the bottom of the fabric.
Posted on Oct 06, 2009
  • 300 Answers
SOURCE: When I sew or embroider with my husqvarna designer
Your check spring or check spring sensor need to be replaced, take it to a Husqvarna repair shop, there is nothing you can do yourself..
Posted on Feb 11, 2010
sewinsnap
  • 135 Answers
SOURCE: Bobbin thread is bunching up and wobbling
you don't have it threaded right and you have to make sure the thread is seated between the top tension disc
Posted on Aug 12, 2010
Upside down stitching
Am having a difficult time picturing this. Sounds like the upper thread is creating loops under the fabric and the bobbin thread is showing on the top of the fabric.
Make sure to use a brand new needle.
Remove the thread from the machine
ALWAYS raise the presser foot and rethread the upper thread.
Make sure the thread path is correct.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin thread is threaded through the bobbin tension correctly.
Set the upper tension to the midway point (factory standard), however, this setting may need to be tweaked for your particular machine.
Bring the bobbin to the top of the project Before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Retest--begin sewing slowly.
If the upper thread is still showing on the other side of the fabric, the tension is too loose. If it is pulling the bobbin thread up to the top of the fabric, the upper tension is too tight
OR the bobbin thread tension is too loose. (CAUTION: make only small adjustments to bobbin tension--1/8 of a turn at a time!!! It also helps to mark the screw groove location with magic marker on the bobbin case BEFORE making any changes so you can back it out and return to the original setting.)
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 05, 2016 | Sewing Machines
I have a Baby Lock Audrey. The bobbin thread is "nesting". I have tried rewinding the bobbin and rethreading the needle and bobbin thread but that hasn't helped.
Check that it is actually the bobbin thread that is nesting. Generally, bobbin thread issues appear on the top of the fabric and upper thread issues appear on the underside of the fabric.
If it is in fact the bobbin thread, the bobbin thread tension may be off or malfunctioning.
If it is the upper thread nesting under the fabric:
1. Remove the thread
2. Install a brand new needle
3. ALWAYS RAISE the presser foot. This releases the thread tension so the thread will seat properly.
4. Rethread from the beginning and check the thread path is correct.
5. Set the upper tension at the midway point.
6. Check that the bobbin thread is loaded properly
7. Retest the machine.
If it continues to create thread nests under the fabric, tighten the upper tension.
Jun 22, 2016 | Baby Lock Sewing Machines
My thread bunches under me material and can' t sew
Sounds like "thread nesting" also called "bird nesting." Usually, it is a result of incorrect threading, incorrect tension, or the thread not being properly seated in the tension disk.
Remove the thread.
Install a brand new needle.
RAISE the presser foot and rethread the machine from the beginning making sure the thread path is correct.
Set the upper tension to the midway point between low & high numbers.
Test.
The correct tension is achieved when the upper and bobbin threads meet in the middle of the fabric. If upper thread is looping under the fabric, the upper tension is too loose. If the bobbin thread is appearing on the top of the fabric, the upper tension is too tight. If it is difficult to determine what is happening with tension, try using a different color thread (but ALWAYS the same type & weight) in the bobbin as what is used as upper thread.
Tension is static--it needs to be adjusted whenever a new project is begun because the needle/thread/fabric combination will affect the tension. A sewist should become comfortable with adjusting the upper tension on a piece of the scrap fabric before actually beginning to sew the project.
The needle/thread/fabric need to be compatible to get the best result. All About Needles
Sewing Machine Thread Bunching Up Here Why
http://www.chholderby.com/tips-tricks-and-help/part-4-bird-nesting
Mar 12, 2016 | Sewing Machines
I have singer 4423.The needle thread in bunching up in the bobbin case and not sewing! When it didn't pick up bobbin thread I loosened bobbin tension which fixed that problem.
Sounds like bird nesting.
Remove the upper thread completely. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly according to the manual.
Set the upper tension to the midway point between high & low numbers. Retest on a scrap of fabric.
P.S.--once you get the upper tension correct, you may find you will need to readjust the bobbin tension.
Also make sure that your needle, thread, and fabric are compatible.
All About Needles
Feb 15, 2016 | Singer Sewing Machines
Bobbin threat loose
Make sure you have threaded the machine properly--which usually involves removing the thread and rethread from the beginning. Make sure to RAISE the presser foot before threading the upper thread. Check that the bobbin is loaded in the bobbin case and it is threaded properly.
sewing machine loose bobbin thread Google Search
Jan 26, 2016 | Sewing Machines
Machine saying to rethread the upper thread but not picking up bottom thread from bobbin. Constantly rethreaded upper thread still won't sew.
Consult the owner's manual to make sure it is threaded correctly. Install a brand new needle making sure it is installed properly. Also, be sure to RAISE the presser foot BEFORE threading the upper thread.
If it is still not picking up the bobbin thread, the machine may be out of time.
Jan 20, 2016 | Brother InnovIs QC1000 Electronic Sewing...
How do I adjust the tension?
Set our machine's upper tension dial somewhere around the midpoint (between the lowest & highest number).
RAISE the presser foot and then rethread the upper thread from the very beginning. (The tension disks are released when the presser foot is raised allowing the thread to seat properly.) (When testing tension, it helps to use different color threads in the bobbin vs the top thread so you can see how it is sewing.)
Sew a test on the fabric you will be stitching. The ideal tension is when the upper thread and bobbin thread meet in the middle of the fabric. If the bobbin thread is appearing on the top of the fabric, the upper tension is too tight and needs to be loosened. If the upper thread is appearing under the fabric, the upper tension is too loose and needs to be tightened. Righty-tighty and lefty-loosey!
Nov 19, 2015 | Sewing Machines
The machine is pulling through more bobbin thread than embroidery thread
Sounds like a tension issue. Try rethreading the upper thread first and then lower the upper thread tension.
Jan 27, 2013 | Brother PE770 Computerized Sewing Machine
My sewing machine will pull up the bobbin and looks correct when I start to sew, but then it will not catch it when sewing; therefore, it will not make stitches
Take and rethread the entire machine, sound like it is either the bobbin thread not correctly threaded into the machine or the upper thread isn't being pulled throught the take up lever.
Feb 08, 2011 | Kenmore Drop-In Bobbin 16231 Mechanical...
The bobbin thread is not catching. I have rethreaded the entire machine multiple times, tried different bobbins, etc. However, the needle and thread are not catching the bobbin thread. The bobbin thread is...
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Aug 01, 2010 | Brother Disney PE-180D Computerized Sewing...
Sewing Machines Logo
119 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
