Question about Hardware & Accessories
Westinghouse sb920we Any one has manual? After washing dishes, the machine still have water about a litre on the bottom. Is it faulty?
    Problem Solver:
  • 8 Answers
A small amount is normal .check the drain hose that's is usually hooked to the garage disposer make sure the hose is higher then outlet otherwise water will drain back into the washer,.
Posted on May 17, 2014
Why won't ariston 105 start spin cycle?
Sounds like this could be a blocked/air-locked filter.
easy fix if so.
First. switch off the Machine at the socket.
Check your washing machine user manual for the location of the pump filter access screw. (Normally situated behind a front bottom clip out panel) ensure you have a few towels and a couple of pans/dishes at the ready before releasing the access screw, expect 2 or three litres of water to drain... and whatever is blocking the filter. (could just be an air blockage or a small object) replace the filter screw and clip off panel, switch on at mains.
Hope this helps.
Aug 26, 2014 | Washing Machines
My thoshiba washing machine model aw-a820mm cant be on. when pressing on button it lights blinks n off in seconds. need solution?
This could be a blocked/air-locked filter. common occurance.
easy fix if so.
Hope this helps.
Toshiba washing machine AW-A820MM cannot be on. iwen press on button lights blinks for few seconds and off again. what could be problem?
easy fix if so.
Hope this helps.
Water left on washer
If you mean "Left in washer"
This could be a blocked/air-locked filter. (a common occurrence not a fault.)
easy fix if so.
Hope this helps.
Aug 26, 2014 | Whirlpool Washing Machines
Kenmore 800 water in tub at end of cycle
easy fix if so.
Hope this helps.
Why is no water coming into washer? loading & washing symbols flash.
Check water inlet hose is properly connected and inlet tap (on hose If applicable) switched on.
Alternatively...
This could also be a blocked/air-locked filter. (a common occurrence not a fault.)
easy fix if so.
Hope this helps.
Aug 25, 2014 | Washing Machines
Why washer does not complete cycle?
easy fix if so.
Hope this helps.
My washing machine will not ruN through a complete wash cycle
easy fix if so.
Hope this helps.
Aug 25, 2014 | Indesit Washing Machines
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
0E flashing on Westinghouse LF708C Washing Machine
Had the same problem. After checking that all the hoses etc were clear and no blockages, then suspected that the pump (cost $90 Australian dollar) was faulty. The Westinghouse service technician acknowledged that that was probably the problem, which I then confirmed by pulling out the pump, and then carefully connecting 240V across the pump terminals. Certainly was a faulty pump. So I spent the money on a new pump and installed it and now the washing machine (6 to 7 years old) works fantastically.
Apr 10, 2009 | Westinghouse Washing Machines
Hardware & Accessories Logo
44 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
