Question about Radio Shack Video RF Modulator. 15-1244. New. Channel 3 and 4
Common problem with busted rf modulator - Radio Shack Video RF Modulator. 15-1244. New. Channel 3 and 4
    Genius:
  • 1,224 Answers
Sodder new rf sensor on two wires simple
Posted on May 17, 2014
Rf modulator
so what is your question? they are cheap so I would just buy another one. it would cost to much to fix it.
May 17, 2014 | Radio Shack Video RF Modulator. 15-1244....
Own Atari 2600. Atari not responding to television. (FUZZY SCREEN) One of three problems: 1. I AM NOT CONNECTING SYSTEM CORRECTLY TO TV. please instruct me how. parts i have are: Radio...
Hello!
When powering the stuff there should be light indicated that there is a power on it. how ever if these not been observed, power adapter maybe busted. try to fix it or replace it. Please refer to the atari manual for the correct operation of your stuff.
hpe this help,
melnavz
Mar 14, 2008 | Video Game Consoles & Games
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
No spark on 1 2 3and 4 sillinder coils test ok RF 400 R year 96
test for battery voltage at the coils on the orange/white wire. Also check for battery voltage at the CDI module on the orange/white wire. If voltage is present the most common failure is the signal generator (aka pulser coil)
Jan 16, 2013 | 1998 Suzuki RF 400 R
Snowy image
Your going to need the manual RF modulator to get the sound out because it works off of a different output than the newer ones do. The 2600 runs a closed circuit TV signal to the modulator. In fact there is a small TV transmitter in the game unit.While most electronics today send a seperate audio and video signal. So a modulator that plugs into the electrical outlet won't do the trick.
I found this page on the internet. Look at the RF Option section and see what you think of those options:
http://www.cheeptech.com/2600mods/2600mods.shtml#rfoptions
Jun 29, 2008 | Atari 2600 Console
The video/audio outlet port is busted
okay..... nobody else knew what to do so heres what i did and it works. i bought an rf modulator. i hooked it up to the tv, bypassing the original a/v ports (the modulator has new a/v ports) turned the tv on to the channel i selected on the modulator, and now i have audio and video again.... not sure why my video ports went out in the first place (on 3 tvs-see prior posting by me) but at least we can play games now without buying replacement tvs. good luck!
May 22, 2008 | Nintendo Wii Console
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Nov 08, 2007 | RCA F27242GY 27" TV
RF Modulator
The RF modulator changes the outputs from RCA (red, white, and yellow) to a Coaxial Cable (COAX).
You connect the DVD players RCA outputs to the RCA Inputs on the RF Modulator, then connect the COAX Output from the RF Modulator to the television.
Best of Luck.
Oct 23, 2007 | Car Audio & Video
Need a compositeoutput (F connector) for the Startech SVID4101R
Hi, If your TV has only an F input connector, then chances are that it can only accept an RF (TV/Cable) signal. On the other hand your video/signal source puts out a composite video signal (presumably with audio likewise). What you need is an interface converter or more commonly called "RF Box or RF Modulator". This is a device that embeds your audio/video signal into an RF signal transmitting at a TV channel (commonly 3 or 4). These devices are commercially available. You have to specify whether stereo or mono and what color system is being used in your country such as NTSC, PAL, Secam etc. A fine example is RadioShack's RF Modulator Model: 15-2526, Catalog #: 15-2526 (http://www.radioshack.com). A work around is to use an old VCR where you can plug into its RCA Audio/Video INput your signal source and connect its RF out to the F connector of your TV via a short RG59 Coaxial cable terminated both ends with FP-5 connectors.. You have to select either 3 or 4 (as the case may be) in your TV and set your VCR to VTR operations. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 18, 2007 | StarTech.com 4-to-1 Composite/S-Video and...
Radio Shack Video RF Modulator. 15-1244. New. Channel 3 and 4 Logo
55 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
