Question about Kenmore 24932 Top Load Washer
Kenmore 70 series washer will not drain? It makes an electric click noise which makes me think the lid switch is ok, but i don't know. Won't drain or spin.
Model # ? can't find the darn model #. Thx for any help.
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 650 Answers
There is a good chance the lid switch is bad. The model number is usually under the lid hen you open the lid check at the back of the opening when the water injector is.
Posted on May 17, 2014
catriver
  • 878 Answers
SOURCE: Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Posted on Apr 27, 2007
duby1990
  • 367 Answers
SOURCE: Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Posted on Nov 20, 2008
duby1990
  • 367 Answers
SOURCE: Why My Kenmore 70 Series Washer Won't Drain Or Spin?
You need to replace the lid switch. This is located under the case. you have to take the case off to change this part. This is done by taking the 2 screws out of the front of the control panel. Then flip the panel back and remove the 2 brass clips that hold on the case. Then you can remove the whole washer case to get acces to the lid switch. This is a very common problem and an easy problem to fix.
Posted on Feb 13, 2009
SOURCE: Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Posted on Jul 04, 2009
  • 36 Answers
SOURCE: How to bypass a lid switch on a Kenmore 90 series washer?
bypassing the switch is done by connecting the two(outer 2)wires.thus closing the switch circut to the timer
Posted on Jul 25, 2009
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
My kenmore 70 series won't spin and drain.
A leading problem that will make the washer not drain is a defective lid switch. To check if that is the problem,open the lid and close it slowly,when it is almost closed you should hear a clicking sound,do this a couple times and if you do not hear the click the lid switch is what i would suspect as the problem.
To me a technician with 30 years experience i think the switch is very easy to replace,i believe with some mechinacal ability you too could replace the switch assambly.
If it turns out to be the switch i have attached a youtube video that will show you step by step how to replace it http://youtu.be/MFsvLiuTniU
Good luck,i hope this helps
Gene
Aug 04, 2011 | Washing Machines
Kenmore washer 70 series won't drain...what could be the problem? Is it worth fixing?
Good luck,i hope this helps and if it does please give mea 4 thumbs up rating
Gene
Jul 29, 2011 | Kenmore 22422 Top Load Washer
WAsher BROKE!
lift the lid up and down,if you don't hear any clicking the lid switch broke,if that's not it check the motor coupling,take the two clips off that hold the pump in place,remove the two screws and the two clips that hold the motor in place and the coupling is on the back of the motor,if the washer is dead it's the lid switch,if it makes a grinding noise but doesn't move then it could be the coupling,let me know how you make out
Jul 17, 2010 | Kenmore 22422 Top Load Washer
Kenmore 70 series. It won't agitate, drain, or
Does it make motor noise?
Check for belt issue if there is a motor noise and no spin.
Feb 14, 2010 | Kenmore 22422 Top Load Washer
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer not spinning/draining
The lid switch is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Kenmore 70 series agitates but does not drain or spin cycle.
If the unit is not draining or spinning it sounds like a lid switch. If the unit is draining but not spining it sounds like a drive coupling.
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
Nov 20, 2008 | Kenmore 20722
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24932 Top Load Washer Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
